Question about Proview PL926WBi 19" LCD Monitor
Proview 19inch LCD MA982k model 900p
Hi There Monitor turns on then there are alot of lines vertically.  The screen then blanks and comes up with a no signal message. Its out of waranty, so I took it apart. There is a ribbon cable from the back of the screen to the pcb. When you wiggle the ribbon and lay the monitor on it back, the thing works fine...... Is it the ribbon, the connector or dry joint on the pcb? Any ideas?
Thanks alot
  • 38 Answers
You are on the right track. Sometimes the ribbon cables will look fine but the wire inside the insulation is broken and will result in intermittant problems. Definately check the cable first and repair or replace. It is best to meter the cable while not connected to avoid false readings through other components. Should be a relatively easy repair.
Posted on Jan 18, 2008
Xerox lcd modle number 900p Power supply fault plz send pics of supply 1 ic burst i never know number
How-to Fix KDS K917s Model 900P LCD Computer Monitor ...
? 9:59
Jul 5, 2010 - Uploaded by X2YeZCAMCNC
How-to Fix KDS K917s Model 900P LCD Computer MonitorRepair Screen .... This screen has the exact ... Ac Dc Adapter Charger for Xerox Model 900 ... > ... > Monitors, Inc.... Model 900 Xl592ds Xg-90d Xl370b Xl-370b Lcd Monitor,xerox Xg-70d 17" Lcd ...Power Supply FOR Xerox model 900 XL592DS XG-90D XG-70D XG-71D ...
Nov 23, 2015 | Xerox Computers & Internet
Product NO. PL916s Model NO. 900P I have a Proview monitor, which has always worked wonderfully. Recently my computer broke down and I'm using another computer with a small screen. I have misplaced...
Product NO. PL916s Model NO? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From can find those parts
if you have any question,please let us know,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Jul 21, 2011 | Proview PL916S2 Monitor
My Proview monitor PL916s model# 900P built in 2004 suddenly shut off and will not turn back on. There were no previous problems with it and this is the 2nd monitor (same brand and model) which has done...
My Proview monitor PL916s model? This trouble maybe power supply or inverter boards is defective.
Apr 12, 2011 | Proview PL916S2 Monitor
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel
Aug 12, 2009 | Proview PL916S2 Monitor
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
Proview monitor blacking out
i would suggest getting a new monitor you might have made it overheat or your display driver failed.
Feb 16, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor turns off after 4-5 seconds
hi every one, i hope this helps and am proud to say/or not that i am now using my philips php-19x (aka proview 900w/Mag LT916s Model 900p/ Xerox) and yes turn on the monitor 2 seconds screen goes black and the blue power light stay lit, but if you shine a torch onto the screen you can see the lcd display is working, and if you turn the power off and on the cycle starts again, like most of us we checked the web to no avail, untill yesterday. I have been playing with this monitor for 3 months on and off after a kind fellow gave me this monitor for free on uk freecycle and of course i checked all the caps on the psu/inverter pcb and more components all seemed fine checked the ccfl lamps by taking them out of the lcd panel (15 minutes to dismantle) both lamps where fine not orange, a nice bright light, and knowing that if the monitor started woking ok and the back lights did not fail it would run like this for ever until you turned the monitor off / video blanking so i was convinced that there was no fault with the psu/inverter board, and as i stated i found the solution at last (yeh) and here it is many that's to all on the bad caps forum and of course the main man -----barry wilkins-----
Re: Mag LT916s Model 900p 19" LCD dropping like flies
I have got to the bottom of this ,after I got one of scopes out (PM 97) the output of the TL 494 IC was disappearing .The IC seems to crash easily ,I think the oscillator on pins 5&6 actually stops.
I cleaned the whole board with an aerosol of PCB cleaner and heated up the PCB up with a small craft heat gun to quite hot .
I fitted a 0.01 mfd capacitor across the IC pins 12 to 7 to decouple the VSS supply ,because I felt the cause of the IC stopping could be interference based
The monitor now runs for all day with no sign of the backlights cutting out.
I found out this LCD display was made by proview.
Barry Wilkins
john r uk.
Sep 05, 2008 | Computers & Internet
Monitor works on one computer, but not the other
The problem is not your monitor, but the video card on your computer that it doesn't work on. If the video output on your computer is built in, residing near your keyboard / mouse ports, you can purchase another video card to put into your computer and connect your monitor up to that instead. If it attaches to a separate card inside your computer, just replace it. There are three kinds you can get, AGP, PCI, or PCIe. Make sure you get one that will fit inside your computer.
Jun 26, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
774 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
