The following items are required:
- A copy of the original Windows CD/DVD or ISO.
- A copy of the Boot Files (Downloaded Below).
- A minimum of 1GB available hard disk space for CD's.
A minimum of 5GB available hard disk space for DVD's.
Create a folder called
OS on your hard drive (C: is used in this example).
In this folder create two sub-folder called
BOOT, and
ROOT.
Copy the entire Windows 2000/XP/2003 CD (or extract the ISO) into folder
ROOT.
1.) Download boot file. (bootfiles-from-tacktech-website.zip
~1.34KB)
2.)
Extract the
BootSector file (
boot.ima) from bootfiles-from-tacktech-website.zip
into the folder
C:\OS\BOOTStart
Nero Burning ROM.
Select
File >
New... from the menu.
1.) Select
CD-ROM (Boot).
2.) Select
Image file from
Source of boot image
data.
3.) Check
Enable expert settings (for advanced
users only!).
4.) Set
Kind of
emulation: to
No Emulation.
5.) Set
Load segment of sectors (hex!): to
0000.
6.) Set
Number of loaded sectors: to
4.
7.) Set
Platform identifier: to
Intel x86 compatible.
8.) Press the
Browse... button.
Locate the
BootSector file (boot.ima) in the folder
C:\OS\BOOT.
Click the
Open button.
Click on the
ISO tab.
- Set
File name length to
Max. of 31 chars (ISO Level
2).
- Set
Format to
Mode 1.
- Set
Character
Set to
ISO 9660 (standard ISO CD-ROM).
- Check the
Joliet
check box.
- Check all
Relax ISO
Restrictions.
- Check
Allow more than 64 characters for Joliet names.
Click on the
Label tab.
Remove the check from
Also use the ISO 9660 text for Joliet.
Enter the
Volume
Label into the
ISO 9660 and
Joliet text boxes.
Click the
More fields button.
- View Windows 2000 CD Labels
(TTID# 269)
- View Windows XP SP0 CD Labels (TTID#226)
- View Windows XP SP1 CD
Labels (TTID#283)
- View Windows XP SP1a CD Labels (TTID#312)
- View Windows XP SP2 CD
Labels (TTID#342)
- View Windows XP SP3 CD Labels (TTID#422)
- View Windows 2003 Server
RTM CD Labels (TTID#292)
- View Windows 2003 Server SP1 CD Labels (TTID#355)
- View Windows 2003 Server R2
Disc Labels (TTID#387)
Enter in the
Volume Label into the
System Identifier, Volume Set, Publisher,
Data
preparer, Application text boxes under
ISO 9660 and
Joliet.
Click the
OK button.
Click the
Burn tab.
- Check
Write.
- Check
Finalize CD
(No further writing possible!).
- Set
Write Method to
Disc-at-once. (We have had Track-At-Once work as well.)
- Click the
New button.
- Locate the folder
C:\OS\ROOT.
Select everything in the folder and drag it to the ISO compilation panel.
Note: Some files are not show in the
following image.- Click the
Write CD
Dialog button.
Click the
Boot tab.
- Verify the settings. Correct if needed.
Click the
Burn button.
Wait for Disc creation to finish.
Click the
OK button.
Click the
Done
button.
Process completed. You're done.
Regards
Pcs365.8
