Question about Dryers
Insalling a tumble dryer belt
I have a whiteknight tumble dryer the belt snapped on it and i have ordered a new one just need instructions on how to install it please. any help much appreiaciated.
  • 20 Answers
The top of dryer hindged, snap clips in front, pop clips with scewdriver, front panel should slide up and out or tec scews along inside edge, motor should be on your right side facing drum, motor bolted to botom plate, need to check belt tennsoiner for any type of wear and damage,the rest should be simple,re-assemble dryer.
Posted on Jan 03, 2008
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
Anyone know where I can obtain a copy of a service/troubleshooting manual for Sensordry WhiteKnight tumble dryer? Dryer will not tumble.
You can trace this out without any service manual , to only keep the logic of tracing the voltage to the circuits. Now if the tumble is not working it is the motor not working, so check if the door switch is working and then the program controller.
If there is power to motor is humming check if this has a capacitor. If so check if faulty as the motor will not start.
Sep 30, 2010 | Dryers
Dryer not tumbling
A broken belt is very common. If you hear the motor running, that's probably it. The dryer must be taken all apart to replace the belt. Hopefully instructions will come with the new belt. Routing the belt over the motor shaft and around the tensioner is always a challenge.
Apr 22, 2009 | Candy CDV262 Dryer
How to fix a belt on zanussi tumble dryer model number zdc 46130s
heat elemet works, drum will not tumble. Help. Little odl aldy, Rosemarie
Jan 25, 2009 | Dryers
I Have A Kenwood KTV1W Tumble drier on which the drive belt has snapped. I have ordered a new one but don't know how to access the drum to fit the new belt and how to put it on the drive motor pulley.
There are 4 posidrive screws in the middle of the back plate of the unit, once these are undone the backplate can be removed leaving the drum and motor pulley open to fit the belt
Sep 20, 2008 | Dryers
I have a WhiteKnight CL43 tumble dryer. The drum will not turn without first being turned by hand before quickly closing the door. It will then continue until its time for the drum to reverse and it stops...
Not all that familiar with the Whiteknight dryer series but a dryer is a dryer and your problem sounds like it could be narrowed down to a few things. Based on your description of the problem and without knowing how much use that dryer has been subjected to, it sounds like you have a belt slipping ..or if it is configured like many other dryers..there may be a belt tensioner that came loose. In either case, the drive motor pulley spins andthe belt doesn't have enough tension or friction on the drum to rotate it. You might try cycling it without clothes to see if it spins up... if it does spin ( without assisting it) then once you add the weight of the clothes it doesn't have enough friction to spin the drum. Hope that helps !
Aug 07, 2008 | Dryers
Changing belt
ok hi pretty lady
ok back to dryer, belt go's around drum and tension pully at bottom then to the electric motor
Jan 20, 2008 | Dryers
Dryers Logo
185 people viewed this question
Top Dryers Experts
