Question about Sony Playstation 3 (PS3) Console
My ps3 won't load any games
I have tried everything system restore quick and full,reset default setting still nothing please help!!
  • koffee_21 Jan 03, 2008
    i'm on my second ps3 because of the cd problem. after 20 days, both of the ps3's stopped reading disks, any disk. i've been playing call of duty4, when it froze, both times.. lucky, it's withing the 30 day return period. I suggest that, if you can, to get a FULL refund and get an xbox.. playstion3 is a NIGHTMARE.
  • Chrismahoney Jan 03, 2008
    No discs will load, but system menu loads ok, able to browse the www etc. But will not load any discs of any type.
    Sergeant:
  • 274 Answers
Sounds like the lends need cleaning if that don't work then as so many other people you may have a week motor
Posted on Jan 04, 2008
6ya staff
SOURCE:
PS3 games won't load
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Aug 19, 2011 | Sony Video Game Consoles & Games
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Only comes on when touching the actual power button, not working when pushing the PS button on the controllers. When on, there's no menu, just the wavy blue background, after a few minutes, it says it...
Ironically this happened to me just the other day. What I ended up doing was a complete reset/format. You will lose some data so I hope you have a back up.
Press and hold the power button until the light on the playstation goes red again.
Let off the power button and press again, hold it until you hear two fast beeps.
Once you hear the beeps release the button.
Plug your controller in via the USB cable.
It will now bring you to a recovery menu.
It will give you these options:
  • estart System:
    • Restarts the PLAYSTATION®3 System.
    • Reset all system settings back to default.
    • Checks for corrupt/missing system files.
  • Rebuild Database:
    • Rebuilds the OS for the PLAYSTATION®3.
    • Fresh restore; Deletes everything and starts from Scratch.
  • System Update:
    • Update the PLAYSTATION®3 System
You CAN try restore file system but since you said it froze, it probably won't work again...but you can give it a shot. It didn't work for me. What I ended up having to do was "Restore PS3 System". This will format everything and start from scratch.
Also, another quick fix that you can try would be to pop open the ps3 hard drive case, remove the drive and plug it back in to ensure that it's properly seated.
If none of these work you may have a dead hard drive and it will need to be replaced.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 08, 2011 | Sony Playstation 3 (PS3) Console
My PS3 will not load any games. What can I do?
I had a similar problem. My PS3 did not load the disk based games. It just showed the circle for some seconds in the upper right corner and nothing happend. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
• Restart System: Restarts the PLAYSTATION 3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load game circle is there that shows that it is loading but it never loads
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu.
Jun 14, 2009 | Sony Playstation 3 (PS3) Console
Playstation3 is not loading games at all
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Jun 08, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont load games up
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
Nov 18, 2008 | Sony Playstation 3 (PS3) Console
Ps3 won't play any games all of a suddden
hold down eject button of 12-15 sec to reset drive. worked for me
Nov 30, 2007 | Nintendo Game Boy Advance Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
