Did you just install it????? If not check the batteries and replace them first....check for corroding also....if you just replaced the thermostat did you wire it correctly????/Wire for Wire???? If so if you have 4 wires in your thermostat you require a jumper wire between RH & RC....if you have 5 wires...no jumper is required....is the Furnace power on???
Comments:
Nov 03, 2009
- T^hx for the 2 rating...gave you as much info as I could for you Question...you have to be more specific
my heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs...
(More)
my heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I can kick it back down to 71 and it kicks off..???outside temp between 12 and 25..
I have a Honeywell AM! Thermostatice mixing valve installed on my boiler to control the hot water...
(More)
I have a Honeywell AM! Thermostatice mixing valve installed on my boiler to control the hot water flow. Recently it will run warm for 5 or so minutes then turn cold. It has been relplaced twice so far. After inspecting it myself (no plumbing experience at all, housewife) I believe my service man has been installing it upside down. Whould this have any affect on the part?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
