ASUS P5VD2-MX SE Motherboard
Graphic Card
posted by Turconator on Jan 03, 2008
Hey Im new and something weird went wrong on my computer. I have a Asus P5VD2-MX SE series motherboard and a PC Saffire 1650 Pro as my graphics card. My monitor is plugged in to my graphics card but when i trurned on my monitor yesterday it gave me a "no signal" so I plugged it into my onborad slot and that worked. Do you know how to disable my onboard graphics card in my BIOS? Because I can't seem to find it????? Please help!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 03, 2008
Helpful (85)
koan
Rank:Wiz Wiz
Rating: 89%, 96 votes
First, I would make sure windows is seeing your 1650 properly:
1) Start -> settings -> Control Panel -> Device Manager -> Display Adapters
Do you see the card there? Does windows note any problems? If all is ok, then move on to #2
2) Preperation: have the back of the computer accessible. Unscrew the monitor cable screws from the video card, but do not unplug. We will need to switch between cards quickly later.
3) Setting up the primary monitor in the BIOS. This will make the 1650 the primary monitor until windows begins (see BIOS POST, etc). Get into your BIOS, Select "Advanced" -> Then "Chipset" -> then "Northbridge .." -> Then "AGP and P2P Bridge Configuration"
- Make sure "Primary Graphics Adapter" is set to PCIE
- Now select "Onchip VGA configuration"- Set the "Frame buffer" value to the lowest possible (64MB)
- Save and exit the bios
- If you are plugged into the onbaord VGA, let the computer reboot and wait until windows should have loaded. Do you see the windows output? If not, switch the omnitor plug to the 1650 adapter or vice versa.
-If windows is displayed on the 1650, then go to step 5, other wise go to step 4
4) Setting up the primary monitor in windows (only if onbaord is the primary): Right click on the desktop and select properties, then the settings tab. You should see 2 monitors on the screen, click on each and it will display the adapter/monitor information below. Select the 1650 adapter and then below, select "Make this my primary display from the drop down box". After hitting apply, quickly change the monitor cable to the 1650, a box shoudl show up askign to keep the settigns, choose "yes"
5) Disable the onboard VGA in the windows device manager:
Right click on the onboard VGA and select "Disable"
Done
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Graphic Card:
I don't want to Accept this solution
Solution #2
Not Rated (0)
tom19511
Rank:Guru Guru
Rating: 85%, 1800 votes
Page 71 of this manual will show you how.
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5VD2-MX/e2505_p5vd2-mx_update.pdf
Comment posted on Jan 03, 2008
Thank You!
Can you Help with these Motherboards problems?
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Please suggest me an option??
Hi, you put the link for the audio drive for windows...
My motherboard is asus P5VD2-MX SE and i am running vista...
merhaba anakartim hdd usb gibi goruyor. bunu nasil cozerim
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
