Ps3 tuning cant tune my ps3 into my samsung tv via av cable
  • tomhamilton1 Jan 04, 2008
    Hi Smeags,
    i have the ps3 connected to my tv via HDMI.The problem arises when i try to connect the ps3 to another tv in my sons room.I am connecting through the component cable following the instructions in the ps3 manual but it does not work.Same applies if i try to connect to my other tv via component cable.So i am only able to use the ps3 via HDMI.I have a sony bravia and a samsung CRTV.
    already tried that......no work
  • 790 Answers
Hello!!
Try connecting the PS3 with the different cable ... i mean the problem may lies with cable ... So give atry once ..
Posted on Jan 03, 2008
    Novelist:
    Scholar:
  • 136 Answers
Hi Tom,
I hope I can assume that you have a relatively new TV. I will go through both scenarios.
If your TV supports hdmi cables then you should plug one end of the cable from the PS3 and the other end to your tv in the HDMI input. Make sure on your TV you go to menu - external inputs and navigate to the HDMI mode then you will be fine.
IF you are not using a HDMI cable, then I hope i can assume that you are using component (3 cables of red blue and yellow). Same principles these cables should go from your ps3 to your tv and select the appropriate AV input on your tv for it to work. Note if you are using component cables you will also need to plug the sound cable to your tv or via your receiver.
If you could provide me with more information on your tv model, if you are hooking up your ps3 via a receiver or not then i can help you more promptly.
Thanks
Smeags.
  • Anonymous Jan 07, 2008
    hi Tom
    PS3 sends out progressive 1080p signals, the best signal you can get with component is 1080i. You may want to setup your ps3 to a lower resolution on the PS3 before you connect it to your son's room. Also when you connect the component cables in you will need to select the correct input(AV type) on your samsung crt.
    I will take my PS3 out and connect it to an old TV to test your situation tonight and post my findings. Can you be a bit clearer on the what happens? ie. are you using one cable for video and two for sound or are you using the 3 color cable just for the picture and sound to another source?
    thanks
    smeags.(tristan)
6ya staff
SOURCE:
How to tune thomson tv 14MG135
first is to get it from AV mode which suggests it is on one of the rear audio/video inputs.
If no source or Tv video button on remote look in the menu--once off the AV input it should be able to tune.
Direct hookup with cable or what?
May 02, 2012 | Thomson 14MG135 14" TV
PS3 connected to my TV by Component cables switch to exit2 AV receiver but have no signal
turn onto that channel, then press and hold the ON button untill you hear the beep, it should tune in to your tv
Jan 31, 2012 | Sony Playstation 3 (PS3) Console
I have a ps3 60gb capatible for the ps2 I have it hooked up to the TV but its not showing anything on the TV I have the High Def connectors for the TV
It is a known problem with some high def connectors not working properly. The following should be checked before concluding there is a problem
1. Ensure you have your TV tuned to the right output station for as your ps3 is connected.(for example you cannot have your ps3 connected to the second set of av ports on your tv and your tv is on av1, it has to be on av2)
2. Cross-check the functionality of your ps3 using the default av cables that come with it so as to know if your cable or console is faulty.
3. Ensure that you high-def cables are properly connected.
If all the above prove abortive, you have to see a repairer to check-up your ps3 or tv
Dec 25, 2010 | Sony PlayStation® 3 (60 GB) Console
CONNECT TV,DVD, AND CABLE TOGETHER TO OPTIMIZE THE SOUND QUALITY .
Usually you have to use a couple of external AV Inputs. for the DVD and the Cable goes into the Componet/SVHS input, OR IF TV has a "Cable" "Antenna" socket, an "F" Connector (Female) You can hook up that way and "Tune" your cable channels. Now If you connect up to the Video in, on TV, you must also use corresponding Audio Channel as well. See ir depends on, how many and what sort of inputs you have. But usually you have a couple of AV inputs selectable via menu. Usually Yellow, Video, Red & White, Audio.
Mar 09, 2010 | Samsung TXK2554 25" TV
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
I cant tune in my nintendo do you know what its meant to be set too
Hi your NES should have on it's right hand side 2 Audio Video inputs have you tried connecting it to your TV via Audeo Video Cable and selecting Video channel on your TV dont worry about using the old RF switch they are for older TV Units. Here is a picture of what the AV Cables look like http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/nintendo-nes-audio-video-cable-no-more-tuning.html
Jan 16, 2010 | Nintendo NES Console
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
Dec 26, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
1,178 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
