Question about Epson Stylus Photo R2400 InkJet Printer
Epson 2400 printer prints dark and with slight colour cast
My Epson printer prints too dark, colours not vibrant. Monitor is calibrated, colour managemrnt settings set as told by help line. Had this printer over a year now not a decent print yet I also have a Canon s9000 no problems with this at all and yes I am using the profiles.
  • SalB Jan 03, 2008
    Have tried all this except service the printer if servicing is anything like as expensive as everything else Epson I guess I would be better off buying a new printer (and not an Epson one!)
    I have always used Epson inks, I have now tried some better quality papers and I think the result is a fraction better than the Epson stuff but still not acceptable. I have tried to print from two computers CS2 and 3
  • phil871 Dec 25, 2008
    Same issue. My prints have a dark cast to them, colors are dull and prints come out slightly blurred. I have downloaded the latest profiles, use Epson everything, constantly check and clean printheads but to no avail.
In advanced mode check ICM and open settings. Select picture profile that is correct for your files. You might have to check "more profiles" box on bottom to see all avaliable. I use Nikon raw files with almost(*) profiled Dell Ultrasharp flat screen and my own paper profile. Print matches screen almost perfectly. Without procedure that I just described prints were 1.5 f-stops darker then screen.
Procedure was written from memory, I hope it's accurate enogh.
Simple advice, for trials use small pieces of paper and fast print. Ink and paper are expensive!
(*)Using Color Munki I cannot set brightness low enogh to null the reading on this monitor.
Good luck SalB
Tom
Posted on Jan 21, 2009
Hi I dont wish to sound patronising as im sure you have tried most things but getting decent colour prints can be a minefield and although you can get lucky with some prints to get consistent colours involves a fair degree of knowlege and a meticulous approach. As well as checking your monitor is calibrated, ensure eveything and i mean everything is set correctly in photoshop and your printer settings,this will then give you reasonable prints. Recheck your Photoshop colour settings, photoshop print settings and then finally Epson printer settings. Just one box incorrectly setup can undo the whole process. If you know some with the same printer/photoshop who is printing ok note all their settings, failing that try a good book/web resource. Best of luck Paul
Posted on Apr 30, 2008
  • Epson Master
  • 1,879 Answers
Try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Posted on Jan 03, 2008
Why is the colour in my photographs not printing as they are in my laptop I have added new inks and cleaned the printing heads
Anonymous, there's a whole science of "color management" that you've invoked. First, what you're seeing is truly caused by lack of "calibration" in any stage of your workflow.
Your camera takes pictures, and whatever colors it sees are what it sees.
Your monitor shows you colors, but there's no standard calibration involved.
Your printer prints colors, but it too isn't calibrated to any standard.\
Assume for a minute that your monitor is set up to be a little too dark. You edit the pictures, and lighten them up so they look ok on screen. Now, when you print the picture, it's too light.
I've had similar issues, and have ended up purchasing a monitor calibration tool (Color Munki Smile) to calibrate my monitor, software "Profile Prism" to calibrate my printer, and now the prints I get look almost exactly like what I see on screen...
Sep 11, 2014 | Canon Pixma iP4500 InkJet Printer
I am printing pictures with my new Epson PX730WD and use only original Epson inks and Epson Premium Glossy photo paper; I had to put in a new original Epson black ink cartridge. Initially after printing...
Could be defective printer or maybe that is just the way it works and is unsatisfactory. If not happy with results try another printer after returning the Epsom. Check consumer reports for printers that do great job on photos and go that route.
Aug 28, 2017 | Office Equipment & Supplies
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
Muddy prints
I have the R2400 and the photo prints look muddy. I have tried the same picture on another printer and the colors are vibrant. Why the muddy pictures on such a nice printer?
Mar 23, 2010 | Epson Stylus Photo R2400 InkJet Printer
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The color is not right when printing on a dvd
The reason for this is the vibrant colour on the disc changes the colour
Oct 10, 2009 | Epson Stylus RX580 InkJet Photo Printer
Epson PX800FW prints coming out too red
Hi dotokpa,
There could be a number of reasons for this. The first is that your monitor may not be calibrated for print, so the image you see on your monitor is not actually how it will look when printed. http://epaperpress.com/monitorcal/ is a good website that will explain monitor calibration more in depth and will offer some free programs to calibrate your display.
It may also be that, since your printer is ink cartridge based, that you are running low in ink in some of the color cartridges so I would recommend checking that as well and replacing them if necessary.
Lastly, if you are still having problems you may need to adjust your printer settings, so when you go to print, under advanced tabs, and colour management you may be able to adjust the red, or darkness settings.
Hope this helps and please take a second to rate!
Mar 20, 2009 | Epson Office Equipment & Supplies
Red cast on all prints
Sounds crazy, but have you got the LM (light magenta) and M (magenta) tanks or inks mixed up?
Also - check the profiles, if you've got a colour profile set up, you may have applied it twice, which would make a magenta cast...
Dec 04, 2008 | Epson Stylus 1400 InkJet Photo Printer
I am very keen on sky photography and regularly capture the beautiful delicate colours of the skies. When i check the LCD on my camera i seem to have captured the colours well, however when i download the...
you are dealing with the transform issues behind millions of colors with your capture device, RGB on your monitor, and translating to CMYK for print.
not an easy or simple translation.
www.adobe.com under the photoshop section and support, has some useful information on managing this translation.
May 01, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Photoshop and the R1800
I had the same problem and read everything I could find about it. Finally after tinkering around, I discovered that printing everything using "Photo Enhance" setting produced the best pictures. Also, I use a calibrated monitor and print through Photoshop Elements 5. Lots of Luck! Cyndy
Jan 28, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R2400 InkJet Printer Logo
535 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
