downloaded hp web smart printing and nothing happened. No tool bar or anything. It tells me in add and remove programs that I have it installed but I can't find it and cannot use it. help
Bij het printen van een microsft office publisher document,in dit geval een kalender komt alles...
(More)
Bij het printen van een microsft office publisher document,in dit geval een kalender komt alles scheef op papier te staan wat kan de oorzaak zijn bv dank Henk Bouwneester
how to remove the inkjet cartridge and replace it. I have opened every place i can find - short from...
(More)
how to remove the inkjet cartridge and replace it. I have opened every place i can find - short from removing screws - where is the inkjet cartridge?
When trying to send a fax from an HP 7410 all-in-one all I get is communication error 421 or 242....
(More)
When trying to send a fax from an HP 7410 all-in-one all I get is communication error 421 or 242. What does this mean and how do I fix it?
My HP office jet 6110 - on power up the scanner moves to the right and causes the cogs to grind,...
(More)
My HP office jet 6110 - on power up the scanner moves to the right and causes the cogs to grind, this prevents the printer from doing anything else - I have tried cleaning the scanning glass as per another forum suggestion but this has not cured the problem - any help greatfully received.
On power up the scanner keeps trying to go to the right and makes a grinding noise - it is stopping...
(More)
On power up the scanner keeps trying to go to the right and makes a grinding noise - it is stopping the whole printer from working
