Question about Toshiba Satellite A105 Notebook
Bios password how can remove my bios password
  • 2 more comments
  • Anonymous Feb 29, 2008
    how to do this in toshiba A100/PSAA9L
    reply me in
    freaky.nayan@gmail.com
    please,,,,.
  • Anonymous May 11, 2008
    bios password blocked toshiba tecra a2
  • tipu0003 Jan 14, 2009
    Toshiba Satellite A100 PC Notebook bios password
  • Anonymous Apr 02, 2009
    I need
I found this info ever several blogs regarding this problem. It is a really easy fix, with just a little bit of work and patience. I have a Toshiba Satellite A105-S4014. This should also work on a A100 since they are of the same family.
1) like always with anything that you do when taking your computer apart, take out the battery and unplug it (common sense)
2) Remove the plastic cover piece above the keyboard, called the "keyboard bezel". this is the piece where you can see the speakers. This page gives several pictures as to how to do this. http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-2.htm
**I found it a little bit difficult to get the plastic retaining clips to "pop" loose, but if you are careful, you can use a small screw driver and slowly "wiggle-pry" between the two screen mounts. this is done with the screen all the way back. you could use a paper clip with a little 1/8" bend at tip to do this also. (it is a tight working area) Once these three retaining clips have come loose the others are fairly easy to "pop" Just be patient and work it slowly. once this is bezel is off the rest is super easy.**
3) Remove the keyboard. Remove the two screws that are evident once the bezel has been removed. These hold the keyboard in place. Lift the keyboard up from the screw side and the retaining clips at the front of the keyboard will lift out. (there is no need to pry here). Once the keyboard is loose you will have to either leave it connected, just off to the side, or disconnect it from the mother board. The keyboard cable connector has a black clip along the top of it. just lift this clip up a little and the keyboard cable will slide out. (the keyboard cable does not have a fixed connector, but is just a ribbon that is held in place by the black clip along the top of the keyboard cable connector) Once you have removed it you will better understand what I mean.
4) Remove the wireless card. It is the only card visible at this point. It is connected by metal spring clips. just unclip in a similar fashion as removing ram. You do not need to disconnect the wires connected to card, just move card over to expose area below card.
5) This is where the magic is... you will see C88 clearly labeled right next the jack that the wireless card plugs into. There are two little solder squares (approx 1/16") at this location. *** At this point plug the power adapter to your computer again. ***
You will have to jump the two solder squares at label C88. I used a paper clip to do this. I used pliers to bend a 1/8" long "L" and then "scuffed" up the paperclip with the teeth of the pliers. (my first try at this did not work because the paperclip had a varnish coating on it and did not adequately conduct electricity.) Once you have your paperclip set up (or the one you used to pry the bezel with) hold it in place on these two solder contact squares and press the power button to boot your computer.
6) Your computer should boot right up and bypass the bios password, which is now reset/ erased. (You might see the Windows Error startup screen that gives you different options of start up to choose. If you disconnected your keyboard, just wait for screen to time-out and it will continue on its own) Once you have booted into windows use your mouse pad to shutdown, via start-shutdown method.
7) Disconnect your power. Reinstall your wireless card and keyboard (with screws). Don't reinstall keyboard bezel at this time. Once everything (but bezel) is reinstalled, restart the computer with battery and AC adapter connected. This should boot right into your computer without any trouble. (if for some reason it does not boot up correctly and asks for the bios password again you will be glad you left the bezel off. just redo the steps again.)
8) Go to Toshiba and get the latest Bios for your laptop. here is the link: http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
Choose your computer in menus provided. download the latest bios version. Using a cd burning program like "Nero" burn the image file to a cd. reboot computer and press F12 to choose boot method and boot from cd. this is the best way to update your bios. there is a way to just run from windows but I do not recommend it. This is a way to get into even worse trouble. If you need software to burn Image files just go to Nero and download their trial. It will work for 30 days and will work perfectly for this important task.
I hope this has been of help to those as frustrated as I was. It is long winded but I like things explained fully before diving into a toy that costs a lot of money. I also do not like to send my computer away to some company that may or may not invade my privacy. I have a lot of personal stuff on my computer, as we all do. When the fix is this easy, I would rather do it myself.
SUB
Posted on Feb 04, 2008
Tks man, i follow the instructions and my laptop is like new... :)
Posted on Jun 24, 2009
Worked great
Posted on May 29, 2008
Hi
this is rafi from india (hyd).
its very simple u just remove mother board jumper that's it that password will remove automaticaly.
ok take care by.....
Posted on Jan 03, 2008
I need to reset my Toshiba laptop. It has been a couple of years since I have used the laptop; therefore, I have forgotten the password.
  • How to Reset BIOS Password on a Toshiba Satellite Laptop ... www.youtube.com/watch?v=TbXW6-PngZk
    • BY DIY TECH
    • 5 MIN
    • 365K VIEWS
    2012-07-31 · Video embedded · In this video we reset the BIOS password on a Toshiba Satellite Laptop. Visit our website for more information ...
  • How to remove bios password - Toshiba Laptop - iFixit https://www.ifixit.com/Answers/View/79319/How+to+remove+bios+password I have a Toshiba Satellite C655D-S5136. I forgot my bios password and need to reset it. I already tried removing the CMOS battery, but it still won't let me reset my ...
  • Passwords: setting and removing (for BIOS, Supervisor, and ... support.toshiba.com/support/viewContentDetail?contentId=108503 Passwords: setting and removing (for BIOS, Supervisor, and Windows passwords) ... If you forget the BIOS password, only a Toshiba Authorized Service Provider can ...
  • Reset Toshiba Satellite BIOS Password ' Find Password findpassword.net/reset-toshiba-satellite-bios-password Heres a quick and dirty way to reset the password on the Toshiba Satellite A205 BIOS. Warning! You can only use these tips on your own Toshiba computer if you forgot ...
  • HOW TO REMOVE BIOS PASSWORD ON A TOSHIBA SATELLITE ... www.youtube.com/watch?v=aHLzz77oP4Q
    • BY TIGGAR COMP
    • 7 MIN
    • 233K VIEWS
    2012-04-24 · Video embedded · HOW TO REMOVE BIOS PASSWORD ON A TOSHIBA SATELLITE A305 AND C655D ... How to Reset BIOS Password on a Toshiba Satellite Laptop ...
  • Bypass BIOS password set by faulty Toshiba firmware on ... superuser.com/questions/243413 Bypass BIOS password set by faulty Toshiba firmware on Satellite A55-S1065 ... you cannot reset the bios password of the Toshiba laptop just by removing the CMOS ...
  • How to Reset a Toshiba BIOS Password? - tech-faq.com www.tech-faq.com/reset-toshiba-bios-password.html
    • 2/5
    • 5 RATINGS
    Reset the Toshiba BIOS Password Using Parallel Loopback Plug. Another option to resetting the Toshiba BIOS password on older models is to use a parallel loopback ...
  • Toshiba Satellite BIOS password reset - BIOS - Motherboards www.tomshardware.com > Forum > Motherboards Hi. Does anyone know how to reset the BIOS password for a Toshiba Satellite C660D 19X please? There are a number of very good YouTube videos for almost identical ...
  • How to reset BIOS password on a toshiba laptop - Laptops ... www.tomsguide.com > Forum > Laptop Tech Support Basically, I accidentally set a BIOS password on my parents toshiba laptop. I was messing around and now I don't know how to reset it. I do know what the password is ...
  • Removing BIOS password on Toshiba Satellite Laptop - YouTube www.youtube.com/watch?v=dd06-tVVq8I
    • BY BRAD HYMAN
    • 4 MIN
    • 549K VIEWS
    2012-10-06 · Video embedded · This video will describe how to reset the BIOS password bug on a Toshiba Laptop. What you will need to make sure you do before ...
  • Jun 08, 2016 | Toshiba Computers & Internet
    How do I get into my bios when F2 won't work
    Try tapping the Delete key instead.
    It say here you use F2, but you have to do a complete shutdown rather than a restart. You have to keep tapping as soon as you see a logo or life!
    http://community.acer.com/t5/2014-Archives/How-do-I-access-the-BIOS-on-a-Acer-Aspire-V3-571G-9636/td-p/13751
  • How to Manually Reset a BIOS Password for Acer ' Business ... yourbusiness.azcentral.com/manually-reset-bios-password-acer-18989... How to Manually Reset a BIOS Password for Acer. ... Acer: Aspire One 552 Service Guide; Resources. Minicircuits.com: The Prevention and Control of Electrostatic ...
  • How to reset bios password on Acer Aspire 5742 PEW71 ... www.youtube.com/watch?v=aNR7JZYl2PE
    • BY AFTER HOURS TV & PC REPAIR
    • 2 MIN
    • 149K VIEWS
    2014-01-27 · How to reset bios password on Acer Aspire 5742 PEW71 laptop After Hours Tv & Pc repair. Subscribe Subscribed Unsubscribe 4,157 4K. ...
  • How to remove BIOS password for Acer Aspire 57** Series ... www.youtube.com/watch?v=ox57qUf33Es
    • BY SAMIR
    • 4 MIN
    • 161K VIEWS
    2011-05-11 · How to remove BIOS password for Acer Aspire 57** Series ... How To Remove BIOS Password Using CMOSPWD ... Acer Aspire 5532 Bios Password Removal ...
  • How to Reset a BIOS Password on an Acer Laptop ' Techwalla https://techwalla.com/content/reset-bios-password-acer-laptop How to Reset a BIOS Password on an Acer Laptop. Submitted by Robert Ceville. ... If you do not want to use the command prompt to reset the BIOS password, ...
  • Removal of the BIOS password from an Acer Aspireone ... https://www.evolutionelectronics.net/node/42 Acer Aspire One 756: The metal pins (i.e. jumper) are labeled "CMOS". Next to the 2nd memory slot.
  • Remove a BIOS Password - custhelp.com acer.custhelp.com/.../detail/a_id/29353/~/remove-a-bios-password Remove a BIOS Password . How do I remove my BIOS password? ... as charges may be required for Acer to remove HDD passwords. Share. Delicious ; Digg ; Facebook ;
  • Apr 16, 2016 | Acer Aspire Computers & Internet
    enter the bios using password - go to security page and remove password by entering current password then press enter 2x - save changes to bios then exit.The password is now removed.
    For unknown bios you will need to take it to a Toshiba service center or search for bios removal proceedures available for your model.This video may help.Cheers
    Remove BIOS PASSWORD Toshiba Satelitte 110 149
    May 16, 2014 | Toshiba Equium A110-233 A110-252 A110-276...
    Finding the primary hdd passwor on a dell inspiron 1300
    - You will get the Master Password that will remove both Admin/System Password.
    - Also HardDisk unlocking.
    - You don't need any additional tool (no paperclip...)
    Bios Password - HDD password - Master password - Unlock laptop - Reset bios password - Bios password removal - Bios Password Recovery - Clearing the Bios or CMOS Password
    http://hdd-biospassword.blogspot.com/
    Apr 03, 2011 | Dell Computers & Internet
    I am not able to remove bios password. i had removed the battery for a couple of hours, but still there is a password. i had corrupt my windows 7 and can boot from cd rom bcoz there is a bios password.
    If the BIOS password cannot be remembered, the unit will need to be sent in for password removal. This service is not covered under warranty and charges will apply to have the password removed.
    Please go to Fix My Acer and set the unit up for service requesting BIOS password removal. In the description please use the following: "Requesting BIOSpassword removal".
    Note: This is for the BIOS password only and does not include the Windows login password. Acer does not remove Windows login passwords.
    Nov 26, 2010 | Acer Aspire 5735 Notebook
    I have a Wipro Laptop. His BIOS is Phoenix. It has a CMOS password. How shall I clear the password.\?
    Hi Nayanranjani.
    As you trying to reset the BIOS password, let me provide the required steps.
    You may reset the BIOS password by just removing and inserting the CMOS Battery.
    The CMOS Battery will have the Computer date, time and also the BIOS password saved in it.
    Hence, removing and re-inserting the CMOS password will reset the BIOS password.
    Once the BIOS password is removed, you may assign a new BIOS password.
    Hope this helps.
    Please feel free to ask further questions.
    Aug 18, 2010 | Computers & Internet
    Acer aspire 2920 bios password removing
    The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
    Phoenix Backdoor BIOS Passwords:
    • BIOS
    • CMOS
    • phoenix
    • PHOENIX
    Mar 18, 2010 | Acer Aspire 4720 Notebook
    Bios password
    Feb 15, 2010 | IBM ThinkPad T43 Notebook
    Password problem
    for bios password remove bios cell or clear bios by jumper setting changing.
    for logon password start pc with safe mode.and remove the password
    Aug 21, 2007 | HP OmniBook500 250MB Zip Drive Module...
    Toshiba Satellite A105 Notebook Logo
    468 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
