Question about Dell E151FP 15" Flat Panel LCD Monitor
Milk white screen.
Dear Guru,
My monitor screen goes white, I have to turn it off and put it away for three weeks, after that period i can reconnect my monitor and it works for a few days and it goes white again and I have to disconnect and put away again for three weeks before it works again.
Please help
Regards
John
water@fountainpure.com
  • fountainpure Jan 03, 2008
    Maybe I was not clear enough let me explain. We are talking about a monitor ALONE ( no CPU, no key board, no mouse, nothing is connected to this monitor) under these circumstances I fail to see how ????. Imagine having a monitor alone (just a Monitor) If you power up your monitor alone it should display the dell logo etc then the colour bars moving at different points on the screen my own is milky white if it is powered up at any point in the three week period. I happen to have another monitor just like that and i'm using it on the same computer, You're the expert please explain this phenomenon.
    Regards
    Fountainpure
    Genius:
  • 3,422 Answers
You are having pixel problem..
Pixel guidance will vary according to the flat panel purchased from Dell. E151FP This has a standard 2 bright pixel defect tolerance before Replacement will be valid. As a summary, please see the following guidelines Dell issues regarding
pixel replacement: 1 to 2 Defective Pixels anywhere on screen are not terms for flat panel replacement. Dell does not replace a flat panel if only one or two pixels are out. This also applies to white, black, red, blue, or green pixels. The only exception to the above rule will be if a flat panel has two pixels stuck ON in the center of the screen. The center of the screen is defined as the area of the screen that is four inches horizontally, by three inches vertically.
3 to 5 Defective Pixels on the screen. These are not normally replaced unless the configuration of the defective pixels are a particular nuisance i.e. they are clustered in line of sight. 6 to 10 Defective Pixels The monitor will be replaced automatically if
this amount of defective pixels is found. Adjacent Pixels: Two sets of Adjacent defective pixels are allowed on a flat panel except in the center. If there are more than two anywhere on the screen, it is pronounced defective and the flat panel will be replaced. No adjacent defective pixels are allowed in the center of the screen, this is declared defective and will be replaced.
3 Defective Pixels in a row anywhere on the flat panel is unacceptable. The flat panel will be replaced. Pixels that do not interfere with the line of sight, such as those that are in a corner, do not qualify for replacement.
If you notice more than six (6) fixed pixels on your display, or if there are several fixed pixels in a small area of the screen, refer to the E-mail Dell section under Additional Information to contact Dell Technical Support.
For help with specifics on your Dell system, or additional troubleshooting support, refer to http://www.support.dell.com.
Goodluck,
Don’t forget to rate me as fixya..
Posted on Jan 03, 2008
  • 790 Answers
HELLO!!!
Try updating the display drivers ... Hope it turns goos after the update ...
  • Kanth raj
    Kanth raj Jan 03, 2008
    Hope it turns good after the update... try it and let me know ...
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
if you see that is helpful please don't forget to vote me
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
Guru budmrtn - I couldn't figure out how to post back!
This what I use for all my repair:
Panasonic caps from DIGIKEY
http://dkc3.digikey.com/PDF/US2010/P1648.pdf FM series
http://dkc3.digikey.com/PDF/US2010/P1645.pdf FC series
http://dkc3.digikey.com/PDF/US2010/P1646.pdf FC series
The connector with Pink/white (one lamp), blue/black (second lamp) do not matter which connectors on the inverter board you are using, there should be 2 set of the connectors on the board 1 set for top lamp assembly, 1 set for bottom lamp assembly.
Hope you can get them all fix.
budmrtn@aol.com
Typical connector setup:
Jul 10, 2010 | Samsung SM225BW 22 inch LCD Monitor
Samsung 22'' lcd screen turns on see something for half a second then turns off tried to hook up different computer same problem had two hooked up tot the same computer and same problem on both screens two...
I have had 3 Samsung monitors do the same thing. Before you call Samsung, completely disconnect the monitor from all computers, then power it on. If the monitor is okay you will get a screen that will say something along the lines of "video source not found" in what I believe will be a blue box on the screen.
If you get nothing the internal boards are bad and it is time to send it back to Samsung. Go to Samsung's website, if you have not registered the warranty then do so, you will need the cash register receipt or the invoice from where you purchased the monitor -- you have to send an electronic copy to Samsung to register the warranty. Once registered begin the RMA process. If the monitor is within the warranty period Samsung will actually UPS a replacement montor to you. The process is simple, you go to the UPS Store unpack the replacement, put the sick monitor in the box from Samsung, UPS puts on the prepaid preprinted label, you go home with good monitor and the sick one goes back to Samsung.
May 09, 2009 | Computers & Internet
Samsung Glyde white screen
Your phone has suffered a catastrophic failure... and is not repairable.
Sep 20, 2017 | HTC Verizon XV6700 Cellular Phone
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Philips Unknown Problem
hi i am arun fr india
i have big problem my pc have been this setup entry key detected enter password to unlock the system...
how to slove this problem help me .... plz >>>....
Sep 13, 2007 | Philips 190B6CB/27 19" LCD
Dell E151FP 15" Flat Panel LCD Monitor Logo
193 people viewed this question
Alun Cox
