Jenn-Air JCD2389G Side by Side Refrigerator
Problem for Jenn-Air JCD2389G Side by Side Refrigerator
Water leaking from jenn air refrigerator side by side
By joey therms on Nov 01, 2009
i'm getting water leaking on the floor in front of the unit. It doesn't happen all the time. It puddles in the amount that 2 paper towel will clean up.What could this be? Im wondering if it has anything to do with the ice maker.
Solution #1
posted on Nov 01, 2009
Not Rated)
salde386
Rank: Guru  Refrigerators  Expert
Rating: 94%, 68 votes
check the freezer side and see if there is ice under bottom rack and floor if so you have a clogged drain,follow the floor to the back wall and the bottom of back wall panel,there is a drain there,use hair dryer to melt out and then you need a steamer or something to blow out the drain line,check it by pooring hot water in the drain you'll know if you unclogged it if the water drains through
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JCD2389G Side by Side
Questions and Unsolved Problems for Jenn-Air JCD2389G Side by Side
Do you recommend Jenn-Air JCD2389G Side by Side Refrigerator?
Answer
Answer
JCB2388AT water leaking onto floor from outside bottom of freezer side
Answer
Fridge Side running warm and freezer side OK....what's the problem?
Answer
Had a 4 hour power outage and now fridge room temperature and freezer warming up. cleaned condenser,... (More)
Answer
The problem on my Jenn-Air side-by-side fridge/freezer is that the freezer is about 35 degrees and... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Sedona, AZ
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
