Ms. - I'm so sorry for your loss.
The least difficult and technical way to retrieve the messages to save would be to buy a digital voice recorder as shown here on Amazon.com
Click Here
or any larger store that sells consumer electronics. There's no need for expensive as spending more money would not get you any better quality recordings of your son's messages. The only feature you require is that the device have a USB connection so you could connect it to your PC and save the recordings to your PC hard drive.
Before you start recording messages be aware that because the messages are digital you can replay them as many times as you need to to get the right quality withou causing them any damage.
To start saving the messages you would place the microphone of the digital recorder over the phones speaker on the left side of the phone at about a distance of 4 to 6" to start. The manual for the digital recorder probably would give you specific advice about this.
The recorder works like a minauture tape recorder. To start recording messages press the RECORD button on the digital recorder, a few seconds later hit the phones PLAY/STOP button to begin the message. When the message is finished hit the phones PLAY/STOP button and then the stop button on the recorder. You've recorded the first message. It's a good idea to rewind the recorded message and play it to make sure the quality is adequate (it should not be much different from the original in quality) If it's OK, move on, recording the messages one by one until you are finished.
To save the messages permanently you would plug the recorder into a USB port on your computer and copy the files to the hard drive. As a precaution, please copy the files over to another medium also, either burning them to a CD or DVD or copying them to a USB thumb drive.
I hope this has been helpful. I hope your healing has begun.
Peace,
Mikeywaf
thanks, but i solved the problem: I assigned the button to solitaire and it worked.
than I assigned it to voice recording and worked.
