Question about JVC Car Audio & Video
Error Code OOOSIA?
I have bought a car off a mate and included was a JVC KD-PDR51 Head Unit. After changing the battery I now have the problem where it will only work in demo mode and the display will keep flashing with "OOOSIA". The mate I bought the car off is now on holiday for a couple of weeks and as he has all the documentation for the unit & fitting (it was only put in 3 weeks ago), I cant take it back to halfords myself. Is there a way to override this on the unit manually?
thanks.
    New Friend:
Hi my head unit has just done the same did you manage to sort it out in the end as I can't find any solutions anywhere
Posted on Apr 25, 2010
6ya staff
SOURCE:
Security code for jvc kd 310 head unit
Not only is this post suspicious, but every head unit will have a different code so this is impossible to answer. You may need to speak with the vendor with proof of purchase.
Dec 21, 2017 | JVC Car Audio & Video
Jvc kd-bt11 will not turn on
Its is definitely the extra wire, i had this problem and took it to a shop the power wire has to be ran from the battery with a fuse in between them, you can find a live wire in the dash and splice and put a fuse between them, if you dont feel confident, i would take it to a local shop i did the same thing and they installed for 40$ but i had all of the hardware and the radio was already in the dash just needed power
Feb 20, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
Jvc kd-sh55 head unit
Have you tried pressing the "RESET" button on the stereo? I have a JVC unit in my car and the reset button is a tiny hole behind the detachable face. Take a pencil or a pen and insert the end into the tiny hole an hold for a few seconds. This will reset the stereo and you should be able to eject the CD as you normally would. If it's a mini-disc (8mm) you probably would have to take the unit apart and manually retrieve it - big hassle. Check the owner's manual to find out where the "RESET" button is if it is not behind the face. If you don't have the owner's manual, you can download one from jvc.com.. Hope this helps.
Aug 30, 2008 | JVC KD-SH55 CD Player
Instlling kd-avx1
You can download the manual direct from jvc on their website, all instructions and drawings are present
Apr 29, 2008 | JVC KD-AVX1 Car DVD Player
Jvc g-324
i could find the manual for the KD-G321/322 but not for the 324. However they may be very similar. So if you want the manual for the 321 and 322 it's below. It may be the same way your head unit changes stations.
http://safemanuals.com/user-guide-instructions-owner-manual/JVC/KD-G321%20%40%40%20KD-G322-_F
Jan 01, 2008 | JVC KD-G310 CD Player
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
My l/o works but my speakers running from head unit does not
You have to find the subwoofer setting on your head and turn it all the way up.
Aug 26, 2006 | JVC KD-G320 CD Player
Car Audio & Video Logo
252 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
