My washer is WMD940p it is just gone over a year old now when you switch on the power to the machine...
(More)
My washer is WMD940p it is just gone over a year old now when you switch on the power to the machine it make a load noise i think it is the door lock and when you select a cycle and press start it fills for 1 second then does nothing no error code. all the parts on the machine work like the pump and the motor because the drum moves still but only for 2 seconds. PLEASE COULD SOMEONE HELP BECAUSE NEED TO USE WASHER BECAUSE IT IS CHRISTMAS!!!!
I have an Ultima 1200 washer/dryer that has clogged a few times (E15), and hence been rectified....
(More)
I have an Ultima 1200 washer/dryer that has clogged a few times (E15), and hence been rectified. However, I now get the same message, even after checking the filter, outlet pipes, drum, I have also run the impeller and it seems to function fine. Additionally I have also checked all of the electrical terminals and given them a clean. Any other ideas? Many thanks in advance
There is no display or power on the Hotpoint Ultimer wt960. I've tried changing the fuse with one...
(More)
There is no display or power on the Hotpoint Ultimer wt960. I've tried changing the fuse with one that works and still no joy.
