Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Water dispenser not working
Ice maker is working fine but water dispenser has just decided to stop working, not so much as a drip coming out, and its not locked and there is water all the way to the joint in the bottom of the fridge, so it must be after it runs up the side of the door, could it be frozen or is it the switch valve.
  • 8 more comments
  • Anonymous Mar 27, 2008
    water dispenser not working. I thisnk it is the switch. How do you replace swich? Whirlpool model ED22CQ.
  • dryland May 27, 2008
    Water dispenser stopped working. Ice maker still works.
  • Anonymous Jun 06, 2008
    Watr dispenser not working on side by side refrigerator
  • j_harrinauth Jul 16, 2008
    Re: water dispenser in my fridge only works for a while then stops: however if I take the filter out then re-insert it, it will work for a few hours then stop. I have changed the filter twice and still the problem continues.
    My Fridge is about 6yrs old and the water dispenser was working well until recently. .
  • Anonymous Aug 04, 2008
    water and ice dispensor dont work, making ice fine
  • Anonymous Oct 27, 2008
    We have water all the way to the back of the fridge. The ice maker is fine but we are not getting any water out of the water dispenser. We checked all the connections and lowered the freezer temp. but this hasn't worked either.
  • mapscott Dec 04, 2008
    I am having the ezact same problem, ice maker is full of ice so I now the filter is not frozen but it just hums when you press the button for water...HELP!!
  • Anonymous Dec 04, 2008
    Ice maker is not filling with water. As a result no ice is made.
  • schoollady Apr 28, 2009
    water dispenser became slower and slower and now is not working at all. Is there a filter to clean or a water valve that might need replacing?
    any help would be greatly appreciated. This problem is on a GE profile refrig.
  • Anonymous May 16, 2009
    need instructions!
Fridge freezer is flashing CF what does this mean.
Posted on Aug 04, 2008
THERE IS A SWITCH ON THE DISPENSER BY MOVING THE LEVER WITH YOUR HAND YOU WILL NOTICE,ON OST SITUATIONS,THERE IS ABRACKAT HOLDING SWITCH.IF ITS WORKING,CHECK WATER VALVE IN ABCK OF REFRIGERATOR,
Posted on Jan 03, 2008
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ice maker quit making ice the other day. I finally got under there and checked everything out and it all seems ok. The problem looks like there is no water coming in from the supply line. Why would...
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
When your ice maker dumps and refills with water it will come out the water dispenser with the wires swapped. If it doesn't then I would have to blame it on the solenoid.
If the lines are the same size you can also swap them around to do this check.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it's getting power it should click when you try it and water come out.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 18, 2011 | GE Profile Stainless Bottom-Freezer...
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker is not filling with water to make ice cubes. The water dispenser woorks fine. Any ideas?
Mar 21, 2010 | Refrigerators
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Side by side Frigidaire. The water dispenser
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the tube.. You can take the water line off the valve and watch to see if it drips.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 30, 2009 | Refrigerators
Water leak from ice dispenser line
hi..
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
My jenn air freezer is not making cubes. the
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
259 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
