Question about Kenmore Kitchen Ranges
Preheat Temperature Incorrect
Kenmore Oven Preheat Set 350 Hand Thermometer Indicates 275, but stove beeps to early
Model Number: 790.46582500 Brand: Kenmore Age: 2 years
White Kenmore 30 In" Electric Self Clean Slide-In Range Model #46584
Up until a week a go the Ovenhad been working fine.
This model has a preheat indicator which beeps 3 times when the correct preheated temperature is reached.
Placing a thermometer in the stove reveals a temperature of 275 degrees, when the expected preheat temperature beeping should be 350 degrees.
The oven then continues to keep heating to 350 degrees and then the temperature is maintained at 350 degrees.
Something is giving a false indication that the preheat temperature is reached.
6ya staff
SOURCE:
Anonymous
  • 290 Answers
SOURCE: Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Posted on Oct 29, 2007
derek martin
  • 148 Answers
SOURCE: Takes to long to Preheat
the burner element iside the oven(the rod that glow,s orange) is burned out,even though it glows and the oven is warm,the element is worn out and has to be replaced,unplug the oven,shutt off gas supply to oven,pull off back cover youll see the rod coming thru each end of the rod will have 1 wire unplug the wire off the clip,go back to the inside the oven follow the rod to the back youll see 2 screws holding the rod unscrew and pull rod thru,easy job and elements arent exspensive,but make sure to unplug oven,and shut off gas
Posted on Jul 09, 2008
erpaalai
Eric Duda
  • 999 Answers
SOURCE: 75585891 gas range will not preheat oven.
If I understand it is working just no lighting the preheat lamp? May just be a burned out lamp. Connect a jumper from any of the other indicators to the preheat. If it lights there is a problem in the oven control/thermostat. If it does not light when the other lamp you connected to it lights, it is the lamp.
Eric
Posted on Jun 28, 2009
RED92JEEPER
J. KUYKENDALL
  • 51 Answers
SOURCE: Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Posted on Oct 01, 2009
Dennis Koenig
  • 221 Answers
SOURCE: oven won't heat up
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Posted on Feb 04, 2010
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
Sep 30, 2009 | Kenmore Kitchen Ranges
Oven themostat not set correctly
Your thermomitor may be going or the oven sensor could be the problem. Buy a BRAND NEW thermomitor and put it in the middle of the middle rack and set to 350. After the preheat is done, wait another 10 min and read thermomitor with flashlight through door glass. This will be the MOST accurate way. to tell
Mar 26, 2009 | Kenmore Kitchen Ranges
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
64 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
