Question about Sony Ericsson W850i Cellular Phone
Installing setup
My disk has got damaged so i having trouble geting it installed
    Problem Solver:
  • 16 Answers
Go to Sony site and download the driver for your phone
http://ma3-origin.extranet.sonyericsson.com/drivers/
Step 1
Remove data cable from usb and put it into a different one
Step 2
Connect your phone to the computer with the cable and turn it on.
You might see "Found New Hardware" wizard. DON'T let Windows search for the driver; point it to the driver you just downloaded, and install the drive on your computer.
After the driver as installed you should be working 100%
Posted on Jan 05, 2008
Setup is starting
Have you removed the installation disk or usb drive you are installing from? Your bios is configured to boot from that media. Until it's removed you can't continue with the install.
Oct 21, 2013 | Acer Aspire 5732Z-4855 Notebook
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
Setup error & xp os suported error
You might be having a damaged disk. If you are installing windows XP, replace the installation cd. If you have windows XP already installed, a damage to your hard disk caused the error. You will therefore have to use the installation CD to scan the disk to fix errors, or install windows XP afresh.
Dec 01, 2010 | Computers & Internet
Keep geting a message setup nps wat do ido
Install a fresh copy of OS. This will resolve this hectic issue.
Regards;
Hasan
Dec 30, 2009 | Acer TravelMate 517TE Notebook
Winxp setup fails in the begining
check the capacitor componen on mainboard if any wrong repair it, this problem is because some voltage is down947202f.jpg
Aug 18, 2009 | Computers & Internet
My a300 canot get to the advanced boot screen pressing f8, it just asks for a bootable disk. after the toshiba screen it says that there is no bootable device. i want to just reset my computer to the...
Your OS is not booting. There may be few reasons.
1) Your hard disk is damaged and your BIOS does not recognise your HDD. Goto BIOS setup and see whether your HDD is shown. If it does not appear there, you may have to replace the Hard Disk.
2) Your HDD is recognised by the BIOS but Master Boot Record (MBR) is missing or damaged. Try booting from an XP CD. See whether Windows Setup detects your HDD. If the setup says there is an existing installation, try repairing it. After repairing, reboot and see whether you can use the computer. Otherwise make a new installation.
Aug 12, 2009 | Toshiba Satellite A300-0CF035 Notebook
'unexpected error' on install
I have two ideas, One is that the software is not compatable with the hardware. You may need to get a newer copy of the software. Two the disk is damaged so you buy a resurfacing tool and see if any scratches can be removed.
Robert Matheson
rmatheson@wowway.com
Dec 31, 2008 | Computers & Internet
Problem installing,deluxe version 7,greeting card
insert disk
click on MYCOMPUTER and then RIGHT-CLICK on the drive and then click or EXPLORE
This should open a folder for the disk. somewhere in there should be an EXE file with SETUP in the title.
if the folder doesn't display the contents you may have a bad disk
if it does and you cant find a setup program let me know.
is this the only disk you have had trouble with lately?
Dec 26, 2008 | Nova Development Art Explosion Greeting...
Hp photosmart c4280 all in one needs disk install & I don't remember when to plug in cords
You do not connect the USB cable until you run the software and it prompts you to connect it.
Here is a link to the setup guide in pdf format:
C4280 Setup guide
Oct 27, 2008 | HP Photosmart C4280 Aio Printer
How to install lexmark 3500=4500 series printer without setup disk
To all Lexmark owners with the lost disk problem.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
If you instead want to purchase a new disk, bear in mind that Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
Oct 21, 2008 | OKI C5100n Laser Printer
Sony Ericsson W850i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
