Question about Dell Latitude D600 Notebook
Ethernet card problem
Hi! In addition, two of my colleagues have same problem with dell latitude. They try to use it in some hotels with wired connection first boot the local area connection in the network connection doesn't appear when they try to shutdown the laptop after few minutes turned it on finally the local area connection came up. The things is every time that they use it in different location still the problem exist. Windows XP SP2, updated all the patches and drivers from the Dell website. How can it be fix? Thanks.
  • 556 Answers
I have a Dell Inspiron and when it operates on batteries it automatically (by default) shuts down the wired network adapter when not in use. The solution may be to insure the network cable is plugged in before starting the laptop or to learn where in the power management utilities to turn on the wired network adapter -- I believe it can be done permanently at the cost of reducing battery operating time overall. It can probably also be done on a when needed basis. My Dell currently does not have windows on it and the operation on my machine may not be the same as on a Latitude. When this happened I used to get little balloon notices from a systool bar icon, however I also modified the default configuration to show my network devices in the systool bar when connected as well as when disconnected.
Posted on Jan 03, 2008
  • david Jan 04, 2008
    You may wish to research your system based on these comments from the middle of page 6 first column of the whitepaper referenced in the link below (the gray box and the paragraph around the gray box) by Dell concerning Power Management on the Latitude C600. All this indicates that the problem indicated is possible. Also it may not be the problem in your case. In addition, it does not appear to be the default setting on the Latitude C600.
    To read this you will need Adobe Reader (Free)
    you can access it using the "Get Adobe Reader" button on the following link, if needed
    http://www.adobe/com
    The white paper --
    http://www.dell.com/downloads/global/vec...
    The contents which may describe your problem -- no guarantee.
    Around the gray box
    "Current Windows operating systems also allow users to disable certain hardware devices that are not used when the portable computer is running on battery power. This is accomplished using the Windows Device Manager accessible in the System icon of the Control Panel. For example, a system can be configured to temporarily disable the 10/100/1000 Ethernet LAN controller when running on battery power. Or, executing the above process while on battery will cause the device to automatically be disabled in the future when the system is running on battery power."
    And the Gray Box (may not have an option for the wired ethernet adapter)
    "Dell QuickSet
    Quickset is a software interface available on Dell notebooks since 2002 that enables easy control over key features. QuickSet makes it easy to customize settings for travel or presentations, and its power management interface provides quick access to standard or customer-defined power schemes Using the Power Management Wizard, a customer defines settings for standby and hibernate modes, as well as power schemes that can turn off the display and hard drive, set display brightness, and define wireless activity. These schemes are customized for operation on and off battery."
    Following this is the Current Dell Quickset link for the Latitude D600 (your machine). This is technical documentation of the latest and greatest version of Quickset applicable to your machine. in the middle of the Description paragraph it indicates it can control "Internal network card activity (depending on your system)".
    http://support.dell.com/support/download...
    In the following link extracted from the bottom of the above page ("View compatible systems and operating systems") it indicates in addition to your latitude D600 this software is also applicable to my Inspiron 5160.
    http://support.dell.com/support/topics/g...
    I really hope an investigation of either quickset or the device manager will indicate the cause of the issue you have with the operation of your Latitude D600.
I am using the Dell Latitude D620, When i am connecting this machine on network I am getting 100 MBPS connectivity, but when i am connecting other machine to the same network port I am getting 1GBPS...
Hi Ajay,
The LAN (wired network) connectivity speed/data rate depends upon the networking hardware (Laptop Ethernet Cards, Switch, Router etc.).
To get 1Gbps connectivity you must have 1Gbps ethernet (LAN) card in the laptops. As Dell Latitude D620 has 1Gbps card, the problem could be with the switch or router, which may be having 100Mbps and 1Gbps ports, depending upon the equipment you are using and it is recommended that you check out the its full specification. If you connect laptop to 100Mbps port you can only get 100Mbps speed. To get full speed, it is required to have 1Gbps support at both ends.
Dont forget to rate the solution if it helps!!
CreativeTECH
Dec 03, 2010 | Dell Ethernet Card Network Adapter
Dell Latitude C600, Ethernet adaptor NOT FOUND
Visit the Dell Web Site.. Use the Service tag on On under side of laptop.. and All Drivers are on the Dell Support Web Site!
Oct 09, 2009 | Dell Latitude C600 Notebook
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
Dell latitude cannot connect to wireless but can through ethernet
ever thought that the wireless card might be disabled or you set it to off?
Apr 18, 2009 | Dell Latitude C840 Notebook
Need a driver
its really simple,u can call the dell technical support and ask them for the media kit for ur latitude and they'll provide u with a complete cd for all the drivers.
Oct 06, 2008 | Dell Latitude C600 Notebook
PC CARD WONT WORK
Sounds as though theres no power getting to the card if theres no light on it - the dell 6XX series has a weakness in the PCMCIA connector too - it can easily flex and seperate from the socket on the motherboard over time and especially in transit. I wouldnt suggest trying to fix it yourself but dell will send someone out to fix it if its under warranty or for a small fee if not. hope this helps
Sep 30, 2008 | Dell Latitude C610 Notebook
Laptop computer wireless problem
i have no sonud device install in my laptop , please tell me how can i install the sound device
Sep 29, 2008 | Dell Latitude C610 Notebook
Ethernet port doesn't recognize internet
ok i have herd of service pack 2 causing these problems, go to dell website , see if there are any service pack 2 fixes to download for your model laptop , or any updated drivers for your laptop , it does almost sound like a Harware problem , but i dont think thats the case , reinstaling xp may be the solution , start from scratch , and take note of what you install , as it maybe be some other software / programs causing this, it's also possible it is spyware or a virus causing this , spware doctor is a good program to use , you can download it for free and do a check , but u will need to buy it to clean the infections, unless u know how to pirate it, which i dont think im allowed to say ,
Nov 20, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
467 people viewed this question
Alun Cox
