Question about Indesit 23 in. DV62 IX Built-in Dishwasher
INDESIT DW S 60
When I press "Power Button", and C Program Push Button 2, "D" Program button lit as well as "B" Power Button, but Machine doesn't start when door are closed. When buttons 3 and 4 on Programme Pannel are pressed nothing is lit. I cheched switch on the door (is functional). I checked also discharge pump and all filters. Everything found OK. Please revert with some instructions.
here in Croatia and on the islands is not easy to find adequate Service Engineer.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Check and make sure the door switch is activating
Posted on Jan 03, 2008
  • Rene Jan 03, 2008
    sorry...meaning there is defnatley a circut through it
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
My dishwasher from ikea renlig dw 60, is 6 month old and now the light to select the programs stay red all the time and pressing the selection button doesnt do anything. Thanks for your help
Similar just happened to us. Turned power off, waited a while, opened door. pressed and held power on button then pressed and held also the select button. Brought it back to life. End leds lit up and i could then select and worked when i shut the door. Ours is a smaller Renlig. Good luck.
May 27, 2011 | Dishwashers
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
In which way can i reset my dw AEG favorit F 86050 vi?
There are 6 program buttons on the right side of the On/Off button.
Press and hold button 1 2 ( 70
Sep 04, 2010 | AEG 24 in. Favorit 86050Vi Built-in...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
What does the " Power " light on the dash indicate when it is lit on my Forester 2.0 Turbo S auto ? The manual doesn`t mention it !
Do you have a switch (usually a push button) on or near your shifter labeled "Power" or "Performance"? Some cars have a button that can turn on a different shift program for the transmission, usually holding gears longer and firming up shifts. Once you locate this button press it again and the light should turn off.
Oct 25, 2009 | 1999 Subaru Forester
Machine wont fill with water.i have checked pipes and they are okay.if you turn program knob to the spin cycle it will try to enpty.also you can still open the door
Hi there....looking at the programe selector knob....you should see at three positions on the panel a black dot.....ok.......(1) close the door of the machine and switch on the power....(2) turn the programe knob to any one of the dot positions....(2) push the start button....a red indicator lamp should flash 3times and then remain steady indicating the program has been cancelled....(3) Now select a new wash program and push the start button....machine should operate ok....If not check the drain pump to ensure it is not blocked...or wiring loose ...or burned out....if this is ok...then your most likley looking at a module failure...
regards Sir Galahad
Sep 03, 2009 | Indesit W 123 Front Load Washer
Program remote
2 ways to program this remote.
Auto Program JER-323
1. Press the device button, ex. TV and the power button for 3 seconds until the on/off button stays lit.
2. Once the on/off button is lit, press the on/off button until the unit turns off. (if you have a code skip this step and enter the code #)
3. When the code is located, press the stop button at the bottom to save the code.
May 07, 2008 | Jensen JER-323 Remote Control
JER 323
May 01, 2008 | Jensen 143307 Remote Control
Open Questions:
See all Indesit 23 in. DV62 IX Built-in Dishwasher Questions
Indesit 23 in. DV62 IX Built-in Dishwasher Logo
340 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
