Question about Garmin StreetPilot i3 GPS Receiver
My GPS Unit does not say the leading decimal point in distance.
When I am driving, the voice gives the wrong distance when to turn. It says to turn left in 6 miles instead of .6. When I glance down and check the map, it correct. How do I fix this problem?
  • droopydog Jan 01, 2009
    I have the same problem, does not say point miles under one mile, with a Garmin 205W model...called Garmin, they say that this problem has been reported and staff will update software to fix?
  • 174 Answers
The voice say "point 6 miles" it does not say "6 tenth miles"
Posted on Jan 04, 2008
On chart page,depth numbers sometime have a subscript number to their lower right. What is that?
These are tenths of a meter. It is written that way to be clearer. Suppose the depth is 10.5 metres. If it were written as 10.5 the decimal point might not be clear and could lead to confusion so they put the decimal lower and to the right.
Jun 19, 2014 | Raymarine RC400 GPS Receiver
Voice somtimes not work
wrong voice installed, they come in 2 versions. 32mb or 64mb depending on model of the tomtom unit. downloading off share sites and just installing is not allways the right way
Feb 08, 2013 | Tomtom GO 750 LIVE GPS Receiver
My HDD Dell 300GB 15K 3.5" SAS, i used with Windows Server 2008 Enterprise. The problem after installing the hdd total capacity its 279 How can manage this? Thank you
Hard drive manufacturers market drives in terms of decimal (base 10) capacity. In decimal notation, one megabyte (MB) is equal to 1,000,000 bytes, one gigabyte (GB) is equal to 1,000,000,000 bytes, and one terabyte (TB) is equal to 1,000,000,000,000 bytes.
Programs such as FDISK, system BIOS, Windows, and MacOS use the binary (base 2) numbering system. In the binary numbering system, one megabyte is equal to 1,048,576 bytes, one gigabyte is equal to 1,073,741,824 bytes, and one terabyte is equal to 1,099,511,627,776 bytes.
Simply put, decimal and binary translates to the same amount of storage capacity. Let's say you wanted to measure the distance from point A to point B. The distance from A to B is 1 kilometer or .621 miles. It is the same distance, but it is reported differently due to the measurement.
Capacity Calculation Formula
Decimal capacity / 1,048,576 = Binary MB capacity
Decimal capacity / 1,073,741,824 = Binary GB capacity
Decimal capacity / 1,099,511,627,776 = Decimal TB capacity
A 500 GB hard drive is approximately 500,000,000,000 bytes (500 x 1,000,000,000).
500,000,000,000 / 1,048,576 = 476,837 megabytes (MB) = 465 gigabytes (GB)
Mar 07, 2011 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
The distance for the trip in my favorite is wrong.
Sounds like you might have "off road" selected for your navigation preference. Shortest distance between 2 points is a straight line, or great circle for GPS units. As the crow flies will be shorter than a road route.
Jul 04, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 265 to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
My garmin 750 doesn't identify the streets that i should be turning at.Just tells me distance when to turn.
Do you mean it is not speaking the street names? Have you selected a voice that uses the Text-to-speach (TTS) feature? From the main screen press, "Tools", then "Settings", then "Language." Next to the voices that will speak street names, you will see the (TTS) designation. Press one of these and the unit should tell you the street names.
Mar 04, 2010 | Garmin nuvi 750 GPS Receiver
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
the Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Jul 16, 2009 | Garmin Edge 705 Handheld GPS Receiver
Why stopped voicing street names?
As far as I am aware, Streetpilot C330 doesn't call street names. Check this specifications sheet on garmin's website:
Jan 13, 2009 | Garmin StreetPilot C330 GPS Receiver
Hye! here's how you can take care of this issue: Dowload google maps from the web (for windows mobile) & install it on your diamond. In order to use GPS on this phone, your internet/gprs connection must be functional; without netwrok connectivity you cant use GPS on this device as it does not have the map interface on its chip (& cant be loaded later too). It just has a light GPS transceiver which in presence of a mapping software (such as google maps) can show your position on the globe & in some countires can also navigate you. After installing google maps, make sure your internet connectivity is on and then work with google maps 'USE GPS' & 'My location' or 'Navigate' functions ... enjoy!
Aug 25, 2008 | HTC Touch Diamond Smartphone
Kenwood KNA DV3200
IF there is no route guidance it is because the unit is not receiving VSS information from the vehicle.  Confirm that you are getting the VSS info from the correct source and or use Rostra Precision Control's cruise control guide to confirm your VSS wire.
Oct 12, 2007 | GPS
Garmin StreetPilot i3 GPS Receiver Logo
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
