Question about Envision EN9410 19" Flat Panel LCD Monitor
Preset My preset is only 800X600. any way to change to native? Only have 2 settings 800X600 and 1024X768. At higher setting picture is not smooth. Can I fix? It's OK at lower setting of 800x600
  • 81 Answers
Without knowing any more about your system I can only give you a couple of general ideas.
First try updating to the newest video card drivers possible.
You can try going to the drivers tab in display adapters in device manager and click update drivers.
Failing this, if your system is more than a few years old you will probably have to update to a more current video card to get the resolution that you need.
The native resolution for your screen is 1280x1024.
Posted on Jan 05, 2008
Preset ringtone level in my Nokia Lumia 60 is to low (13/30). How I can set higher preset ringtone level after power on. I can't find setting option.
CLICK HERE to go to a windows phone forum, where many people are \'upset\' that the volume for the ringtone, the earphone volume and music all change together. It seems to be a big pain.
Oct 18, 2013 | Nokia Lumia 620
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
I can't figure out how to set the radio station pre sets
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
Dec 24, 2010 | Teac CD-X9 Shelf System
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
Blurred screen
There is the possiblility that this program may have corrupted the video driver or a similar issue.
You may be able to go to system restore and back the computer up a day before you installed that program...all your settings will go back to that point but any data you have added will still be there.
Aug 31, 2009 | BenQ FP71E 17" LCD Monitor
Projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
Jan 20, 2009 | BenQ PB6100 Multimedia Projector
Gateway laptop screen off
Probably the resolution or refresh rate is too high. Try setting 800x600 60Hz and if it works try going higher.
Look up what the 'native resolution' of your monitor is on Google or manual and use that setting for best picture
Aug 02, 2008 | Computers & Internet
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
I have a multisync mt840 in my work shop
What is the resolution set at on the laptop/pc connected to the projector? The native resolution for this projector is 800X600 and the max is 1024X768.
Oct 24, 2007 | NEC MultiSync MT840 Multimedia Projector
Envision EN9410 19" Flat Panel LCD Monitor Logo
97 people viewed this question
Top Envision Computers & Internet Experts
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
