Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch WFD 2460 Washig Machine
Hi - wondered if anyone can answer a question about my washing machine. I have just inhertited a Bosch washing machine(approx 6yrs old - I think) from my parents.
Is it normal that the washing comes out warm? I presume that the machine is rinsing with warm water - thought this is wasting warm water/energy. Is there a setting I should know about? I have read through the manual and it doesn't seem to refer to it.
Many thanks in advance for anyones help!
  • Carolime J Jan 03, 2008
    Many thanks for that tip! Don't know why I didn't think of that! The taps were actually incorrectly marked H/C so we connected the wrong hose to the wrong tap!
    Problem now solved!!
    Thanks again!
    Caroline J
Does anyone know of the Bosch WFD 2460 can be used as cold fill only please?
Posted on Apr 01, 2010
  • 209 Answers
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Posted on Jan 03, 2008
I have a bosch wfd 2473 washing machine it will not pump or spin, i have removed the water by releasing the filter there is nothing within the filter and the pump spins quite freely .i could not syphon the...
bosch wfd 2473 washing machine it will not pump or spin This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 27, 2012 | Washing Machines
My bosch wfd 2460 won't spin and drain
Needs to drain 1st then spins after this if not draining .Clean filter take out small hose next to filter to assist in removing water 1st if drum quite full ..Then clean filter this should cure,,,
Nov 16, 2009 | Washing Machines
How do I change the heating element on a Bosch wfd 2460?
go through this link to know your product better before fixing it:
Jun 08, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Not spinning
Axxis+ WFR 2460 Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
WFD 2460 washes but no drain or spin
check the filter and check for foreign object stuck in pump impellor
Jul 23, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Inner drum of my 7 year old washer WFD 2460 rattles on spin and seems unsupported. The rubber surround is intact, is it the only means to support the drum? Thanks. J.Reeve
Hi there!
I would say it is the rear drum bearing which needs replacement. This is what supports the load of the entire drum. The seal is just a water seal.
The good news is that it's a bosch, and replacements are easily available. You are lucky to get 7 years use without problems. Cheaper models give up after 12 months!
Check online for spares under the model number, or have it replacd by a local technician. It is the main drum bearing you need.
If this assists to a solution, Please take a moment to rate as fixya! Thanks.
Jun 18, 2008 | Bosch Washing Machines
Bosch washing machine not getting hot
one of 2 things, eather the element is faulty or the electronic control board wich puts power to the element is faulty.
more likely to be the element
Feb 21, 2008 | Bosch WFL 2063 Front Load Washer
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
1,413 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
