Question about Microsoft SQL Server Standard Edition for PC
Error while trying to login to database
Today i am set all the step connect SQL Server 2000 with MyEclipse but some Error arrived Like
[MicroSoft][SQL Server 2000 Driver]Error establishing sokcet.
plzz help me .
solve this condition how i can do for remove sokect connection.
Rohit Sharma
    New Friend:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
You have a named instance installed with dynamic ports configured (default) named "local". In this case, the connection string would be localhost\local instead of local:1433. You could alternatively configure the service to use a fixed port and then connect using just localhost:. With dynamic ports, you would have to resolve the name of the service through SqlBrowser, which should be running
Posted on Nov 04, 2017
2 Suggested Answers
  • 17 Answers
SOURCE: Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
and here is Microsoft's information
Posted on Jan 22, 2008
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
You can read up more on SQL Server here.
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
I can't connect the ms-sql database with flex
It sounds like you don't have the proper authentication to access the SQL server from the error code you are receiving. I would ask you SQL DBA to check on the permissions within SQL and verify that you have the proper access rights to the database you are connecting too. It is SQL throwing that exception error...
J the Guru
Jun 27, 2017 | Microsoft SQL Server 2000 Standard Edition...
SQL Server 2005 set up ... ERROR Replprov .dll
are you installing from DVD ?
Maybe try copying installation to local drive.
Do not copy to desktop or other sub folder of "Documents and Setting" as this causes other problems in some cases.
Oct 17, 2008 | Microsoft SQL Server 2000 Standard Edition...
Perform following steps to recover sql server database:
  • Create a database with same size that you are trying to recover
  • Shutdown the SQL server
  • Swap old mdf file with new mdf file
  • Start the SQL server
  • Database may go in suspect
  • Set database in emergency mode
  • Run DBCC CHECKDB with repair_allow_data_loss to repair database
USE [master]
It may result some data loss. If you don't want to lose any single data then use 3rd party SQL repair software from Stellar Phoenix.
Mar 19, 2008 | Computers & Internet
Jan 03, 2008 | Microsoft SQL Server Standard Edition for...
MyEclipse6.0.1 connection with sqlserver 2000
Try with MS SqlServer 2005 JDBC Driver,
i had a similar problem with 2000 jdbc driver
Dec 03, 2007 | Microsoft SQL Server Standard Edition for...
SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Aug 30, 2007 | Microsoft SQL Server 2000 Standard Edition...
Microsoft SQL Server Standard Edition for PC Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
