Question about Microsoft SQL Server Standard Edition for PC
[MicroSoft][SQL Server 2000 Driver]Error establishing sokcet
Today i am set all the step connect SQL Server 2000 with MyEclipse but some Error arrived Like
Error while trying to login to database
[MicroSoft][SQL Server 2000 Driver]Error establishing sokcet.
plzz help me .
solve this condition how i can do for remove sokect connection.
Rohit Sharma
2 Suggested Answers
  • 17 Answers
SOURCE: Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-7813.html
and here is Microsoft's information
http://support.microsoft.com/kb/313178
Posted on Jan 22, 2008
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Transaction replication is poosible in sql server devlper edition
SQL Server 2005 provides a lot of benefits over SQL Server 2000 including within the replication feature set.
You might be relieved to know that, although most of the benefits accrue on the side of a SQL Server 2005 Publisher, you can still set up SQL Server 2005 as a subscriber on a SQL Server 2000 Publisher. Thus, you can begin to merge in the newest release of SQL Server into an existing replication scheme. You can read more about this at http://msdn2.microsoft.com/en-us/library/ms217330.
Although major advantage to SQL Server 2005 over 2000 is that changes to the schema, such as through ALTER TABLE statements, replicate out to all subscribing servers. The cool news in a mixed version environment is that the ALTER TABLE statements will be published to SQL Server 2000 Subscribers from a SQL Server 2005 Publisher.
Very cool!
Jan 30, 2009 | Televison & Video
I can't connect the ms-sql database with flex
It sounds like you don't have the proper authentication to access the SQL server from the error code you are receiving. I would ask you SQL DBA to check on the permissions within SQL and verify that you have the proper access rights to the database you are connecting too. It is SQL throwing that exception error...
Cheers!
J the Guru
Jun 27, 2017 | Microsoft SQL Server 2000 Standard Edition...
Connecting of SQL Server and .net
TITLE: Connect to Server
Cannot connect to KRISHNA-02E4A78\SQLEXPRESS.
ADDITIONAL INFORMATION:
Login failed for user 'KRISHNA-02E4A78\Guest'. (Microsoft SQL Server, Error: 18456)
For help, click: http://go.microsoft.com/fwlink?ProdName=Microsoft+SQL+Server&EvtSrc=MSSQLServer&EvtID=18456&LinkId=20476
BUTTONS:
OK
Jan 10, 2008 | Microsoft SQL Server Standard Edition for...
Jan 03, 2008 | Microsoft SQL Server Standard Edition for...
You have a named instance installed with dynamic ports configured (default) named "local". In this case, the connection string would be localhost\local instead of local:1433. You could alternatively configure the service to use a fixed port and then connect using just localhost:. With dynamic ports, you would have to resolve the name of the service through SqlBrowser, which should be running
Nov 03, 2017 | Microsoft SQL Server Standard Edition for...
MyEclipse6.0.1 connection with sqlserver 2000
hi
Try with MS SqlServer 2005 JDBC Driver,
i had a similar problem with 2000 jdbc driver
Dec 03, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft SQL Server Standard Edition for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
