Question about HP LaserJet 1010 Printer
HP laserjet 1010
Paper stock inside d printer how can i solve this problem
  • 81 Answers
Go to this page on the HP website to access info for clearing a paper jam on your printer:
http://tinyurl.com/33mjqq
Posted on Jan 04, 2008
  • 84 Answers
More information needed to solve this problem icq 475653626
How I set the paper type to card stock or to thin card stock
Usually there is a flatter route for the paper to take through the printer by dropping down a door at the back or side. Inside a switch (often blue) for paper or card stock.
Jan 05, 2016 | Microsoft Computers & Internet
Printer only takes paper from one end resulting in a paper jam
I would not have believe this if I have not actually experienced it. Today, my Canon PIXMA MP470 started feeding my paper crooked, to the right where the feed roller is located. Did some research and found numerous people discovered foreign objects inside their printers. Since I had tried numerous other solutions, such as maintenance cleanings from the printer control area. I decided to unplug the printer, turn it upside down and shake it, hoping to dislodge a foreign object. It didn't work. I then took compressed air and sprayed vigorously inside the printer, and tried it again. It didn't work. I then took some card stock (the type used for making greeting cards), put it into the printer and began printing a word processed document - just something to get the card stock to enter the printer. I manually forced it into the printer as it started to print, then after the card stock was about two inches into the printer I manually pulled the card stock back, and THERE IT WAS! My memory card insertion slot protector from my netbook! Thank you Jesus! It is a small piece of black plastic that had fallen from the top of my printer, where I had foolishly placed it while I was using the memory slot in my netbook. Printer works great again! I hope this helps someone!
Jun 15, 2012 | Canon PIXMA MP470 All-in-One Printer
Card stock paper jammed along with plain paper sheet. I was able to get the card stock paper out but the plain paper is stuck inside.
Left the top lid if you cant get it out that way a lot of these hp printer have door in the back look and see if your printer has it if does just open that back door and take out the paper.
sounds frustrating
best of luck
Mar 10, 2011 | HP DeskJet 6122 InkJet Printer
Dear all, When I try to print on printer Magic Color 24300DL it does not "grab" the paper in the tray. It makes some tries, "rolling" but without any succes.Then I get a Media Jam Tray 1 error,...
I fixed the problem with the machine not grabbing the paper.....I simply opened the main lid and then reached in and pulled out the triangular insert (DRUM?) and then when you look inside all the way to the bottom....you will see the rubber tongue that actually grabs the paper.....more than likely it will be dried out or dirty. If you clean it VERY carefully with a soft moist towelette maybe very little soap....it should clean back to grabbing again...of course I went another step forward and put Take Hold fingertip grip and massaged it into the rubber.......been working great ever since. Thicker stock I have to help with my finger.....but all regular stock should work just fine.....
Aug 09, 2010 | Konica Minolta magicolor 2430 DL Laser...
We use the Datamax Printer to print labels with labelview. The printer itself however keeps saying :position fault" how do I fix that?
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Jul 12, 2010 | Datamax DMX-I-4208 Label Printer
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
May 01, 2009 | Epson Office Equipment & Supplies
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error....
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Jan 05, 2009 | HP Photosmart 7850 InkJet Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
HP LaserJet 1010 Printer Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
