GE JKP27 Electric Double Oven
Problem for GE JKP27 Electric Double Oven
We have a double wall oven which is 16 years old.
By erikacardell on Nov 01, 2009
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I need a new oven.
Solution #1
posted on Nov 17, 2009
Not Rated)
rdesoto
Rank: Apprentice
Rating: 0%, 0 votes
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Was this helpful?
Yes
No
Popular Solutions for GE JKP27 Electric Double Oven
Questions and Unsolved Problems for GE JKP27 Electric Double Oven
Do you recommend GE JKP27 Electric Double Oven?
Answer
Answer
I have a GE model jtp27boa1bb, serial number vt6952640 double oven. The botton unit works, but the... (More)
Answer
i have no fault codes diplayed and the top oven doesnt heat up. The door motor does not engage to... (More)
Answer
clock display - oven temp will go blank. by tapping display will come back on.
Answer
My GE JTP27 Double Oven has the following fault codes flashing: F2, F3, and F5. What is the problem... (More)
Answer
How do I remove the touchpad & control panel assembly on a 27" GE built in double oven
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE JKP27 Electric Double Oven:
Top Oven Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
