Question about SanDisk Sansa m240 MP3 Player
PC won't recognise player
When I plug in my new Sansa player, the PC won't recognise the hardware at all. I tried changing the battery, trying a different lead etc., but still no go.
Help anyone? Am I doing something wrong, or is the player faulty?
  • 2 more comments
  • Anonymous Jan 06, 2008
    It used to work, just plug-and-play, but now it doesn't. My computer recognizes that something is plugged into the USB port, but the Sansa 240 doesn't show up under My Computer, nor can Windows Media Player find it, to sync. It used to work, now it doesn't.
    I've changed to the other USB port, plugged it in, unplugged it. Tried to the power button to the player, but it doesn't do anything.
    Suggestions?
  • Anonymous Feb 16, 2008
    sansa clip, under device maanger them usb controlers it says unknown device, cant get computer to recognize device! help
  • Anonymous Apr 01, 2008
    same problem
  • cmeny8 Apr 02, 2008
    i install the sansa in my computer but do not recognise mi sansa c240 what can i do to fix my problem
I had the same problem with the m250. Updating the driver made it work.
Posted on Mar 30, 2008
My brandnew sansa clip is recognised by my
you should update new firmware first at http://forums.sandisk.com/sansa/
if it still doesn't work, change another one.
Good luck
Jan 12, 2010 | SanDisk Sansa Clip MP3 Player
My PC doesn't recognize MP3 player "sansa e250"
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............
Just make sure it is not Locked or On Hold and then try to turn it on.........
Good Luck.......
Take Care
And now it should recognise it
Jan 22, 2009 | SanDisk Sansa e250 MP3 Player
Connecting Problem
Unplug your Sansa. Uninstall all the Sansa software from your computer, and reinstall the clean version from the Sandisk website. Then, replug the Sansa.
-Tha Mp3 Doctor
Nov 15, 2008 | SanDisk Sansa Clip MP3 Player
C150 frozen
re: frozen player, follow the steps outlined here
Oct 06, 2008 | SanDisk Sansa c150 MP3 Player
Sansa e200
There is one option, not really a fix, just a workaround. Try the player on a different computer computer and see if it is recognnised there. If it is, then use something like a pen drive to transfer music from the PC that doesnt recognise the device to another that does. Now you can transfer music using the WMPlayer sync service.
If your device is not being recognised on many computers, it looks like it is time to chuck it away. You can also try this first though..
1. Remove the player from the PC and switch it off.
2. Restart the computer.
3. Hold the +Volume button and connect to computer.
4. Keep the button pressed for at least 60 secs, and you should see the "Found New Hardware" balloon pop up, indicating that the device has been detected.
If even that fails, then I'm afraid your Sansa player has run its course, and you may need to purchase a new player...:(
Jun 27, 2008 | SanDisk Sansa e200 MP3 Player
I need audiophase k1000 mp3 player drivers
Feb 23, 2008 | MSI MEGA Stick 511 (512 MB) MP3 Player
Sansa m250 Player -No Screen Display after changing new battery
Get the same brand batteries as the original
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Feb 21, 2008 | SanDisk Sansa m250 MP3 Player
PC not recognising hardware
I have had the same probmlem but I've begun to realize that windows vista isn't compatible for the MP3 player when I tried using it with Windows XP -- and it worked fine.
Jan 07, 2008 | SanDisk Sansa m240 MP3 Player
Sansas only work on WinXP or later. Win 2000, ME, 98 and 95 are not supported.
Jan 03, 2008 | SanDisk Sansa m240 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
79 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
