Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Color background, and then C255X error code (x depends of the color imaging unit)
After print, copy shows a Color background, and then, after hundreds of copies, display shows C255X error codes ( x depends of the color of imagine unit )
Some Imagine unit changed, repeat error code. Can you help me?
thanks and best regards
Jantonio
  • José Antonio González
    Thanks a lot, sir fixalot
    a short story:
    - Color background with perfect text copy is printed.
    According to Technical Support of KM, there is some trouble with flat-cable in main PCB right-down corner. If this cable is removed and installed again, 50 % of troubles are fixed.
    - (Meanwhile trouble is not detected, the toner cartridge corresponding to background color, goes wearing out).
    - When the technician intervenes the flat-cable, in the other 50 % of the cases, the codes C255X appear.
    - Some machines, are repaired changing the color's IU.
    - In the rest of the cases, the error code continues appearing.
    May be that trouble disappears, changing main board. I'm waiting for a new one, but i'm going to received it in 2 weeks.
    You have some other advice that can help me?
    Thanks a lot and best regards
    Jantonio
  • 146 Answers
Those codes are related to an abnormal toner to carrier ratio. If you are getting multiple errors that could be a control board failure. I will consult Konica Minolta Solutions and post futher as the information becomes available.
Posted on Jan 03, 2008
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
Black smudge when printing color
Imaging unit is the problem. It's made for 100k but often there is a problem very soon after replacing. There is a belt in this unit and he has a lenght enough for two pages A4. Thats why you have problem on every second page. Try to reassembled it and see what is wrong inside ot imaging unit.
If you ask me...buy new mashine. This one have a hundreds of problems by default.
Pifonski
Nov 23, 2015 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Phaser 7300 dn prints full yellow color background on every page even if the background copy shows no color.
Most likely the yellow drum unit is causing that problem. The charge roller gets worn and makes whatever color it is in print out all the time. That would require replacing the yellow imaging unit.
Feb 20, 2010 | Xerox Phaser 7300DN Laser Printer
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
COF37 error code
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print1.gif cycle, ATVC, or image stabilization sequence.
The sensor for this error is in the black imaging unit not the toner hopper. See the steps below. If that doesn't work then visit my website1.gif for contact and I will sell you a full service and or parts manual on CD.
Step
Check Item
Result
Action
Imaging Unit Bk is installed correctly.
NO
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
NO
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
YES
Change Imaging Unit Bk.
Jan 20, 2008 | Minolta CF2001 Copier
Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Jun 12, 2007 | Minolta CF1501 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
296 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
