Question about Hitachi 50UX57B 50" Rear Projection Television
Adjustment how to adjust picture after lamp replacement?
  • jtdmwsa Jan 04, 2008
    would like adjustment procedure for above
    Novelist:
    Champion:
  • 232 Answers
Hi, no adjustment should be needed after a new lamp is installed, if you installed a new lamp and the picture is not correct you have another problem, BMW Rider
Posted on Jan 04, 2008
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
I REPLACED THE PROJECTOR LAMP ON MY TV . THE PICTURE IS SHARP AND BRIGHT BUT THERE IS A BLUE HAZE IN THE BACKGROUND . iTS MOST NOTICABLE WHEN THE PICTURE ON THE SCREEN IS LOW LIGHT. ARE THERE ANY...
When you replaced the lamp, was it doing the same thing? I doubt the lamp was bad, maybe but doubtful. I would try to adjust the color on it. What kind of TV do you have? I need the model and year.
Jan 24, 2011 | Televison & Video
How do I adjust lamp brightnesss for a Viewsonic PJ550 LCD projector?
hi,
may be ur projector lamps reflector may be faulty. when it comes to the end of its life. the coting inside th reflector will get bubbled and it will peeled of. that's why the light is very low. u can't increase the brightness of lamp. because it is connected to a well regulated power supply. and the supply voltage is as per the specifications of the lamp. you can adjust the brightness through menu. for that press MENU button and selects PICTURE 1 using down arrow and then press ENTER. select BRIGHTNESS and press ENTER. using up and down arrow adjust the brightness. if still not get the desired brightness lamp should replaced.
ok
Dec 15, 2010 | ViewSonic PJ550 Multimedia Projector
Replaced projection lamp because of message on screen to do so. Picture is brighter, but now I have a pinkish margin on top of screen. Is my replacement lamp defective or do I have another problem? Any...
There is no problem. Just adjust the picture by moving it up and down with the help of remote control. It is a small button in the center of top row of buttons ( Left of Green switch on/off button). Then adjusting with the up and down cursor buttons.
Jun 30, 2010 | Sony BRAVIA KDL-46V3000 Television
Poor quality picture. specifically the red is brown and can't be adjusted. the tv is about 3 years old.
If the picture is replace the lamp. Lamp only affects brightness if the color is wacked replace the light engine.
Mar 26, 2010 | JVC HD-56FN97 56" Television
Very dark picture. Video adjustments do not help.
I would check the lamp first. Open the lamp door to see if there is cloudiness near the stem of the lamp. If so, replacing the lamp should make the brightness like when you first bought it.
Oct 11, 2009 | Sony KDF-E50A12U 50" LCD HDTV
Sony-50A2000 HDTV color issue
Your light engine is going bad. I would get an estimate first before trying to net fix.
Oct 03, 2009 | Sony KDS-50A2000 50" HDTV
Recently replaced blown lamp for 50HM67 50 inch tv. Now have picture but clarity is off. Picture / screen words are very blurry. Toshiba referred a local repair company who mentioned that the problem...
If the picture was good before the lamp blew, there might be dust/splatter on the window in front of the lamp. Pull out the lamp assembly and look at the small square glass window that the light shines into. It should be clear and clean. If it is not, clean it gently with isoprophonol alcohol or screen cleaner.
By the way, there is no such thing as convergence adjustment on DLP TVs.
Sep 09, 2009 | Toshiba 50HM67 50" HDTV
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
The picture is red or yellow,
i think you need to adjust the color wheel
Jul 30, 2009 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
