Sony KP-46WT510 46 in. Rear Projection HDTV Television
Problem for Sony KP-46WT510 46 in. Rear Projection HDTV Television
On my sony 46wt510 the pic is blurred and it has
By melsilifa on Nov 01, 2009
on my sony 46wt510 the pic is blurred and it has a bend on top and bottom of the screen. Thank you
Solution #1
posted on Nov 01, 2009
Not Rated)
asnowman
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 95%, 604 votes
What you might be experiencing based on your symptom sounds like a damaged convergence IC.
With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these..
Was this helpful?
Yes
No
Solution #2
Not Rated)
barbu51
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 60 votes
Sounds like convergence problem.Either in the analog and/or digital module,you`ll need a tv repairman to fix that problem.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-46WT510 46 in. Rear
Questions and Unsolved Problems for Sony KP-46WT510 46 in. Rear
Do you recommend Sony KP-46WT510 46 in. Rear Projection HDTV Television?
Answer
Answer
I think one of my bulbs burned out. I was wondering if this is something i can fix myself?
Answer
Sony KP-46WT510 46 in. Rear Projection HDTV has a bluish ghost image/ halo effect mainly on right... (More)
Answer
My sony kp-46wt510 pickture distorted on green (pink color is good), - in the middle of the screen... (More)
Answer
The picture looks blurry like the colors arent balanced and synce. How can i fix this problem.
Answer
When we turn on the tv, power button (timer/standby) just blinks and no picture. Any suggestions?
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
