Make sure that you are installing a fresh/ full charge battery
Remove the battery Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt. If you do not have access to a dif. battery. Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Was this helpful?
Yes
No
Popular Solutions for Kodak EasyShare M1033 Digital
no flashing blue light when plugged in and supposed to be charging. Sometimes the lens does not...
(More)
no flashing blue light when plugged in and supposed to be charging. Sometimes the lens does not return to the camera.
My M1033's lens is acting up. It's fine before I take the picture but after the picture is kind of...
(More)
My M1033's lens is acting up. It's fine before I take the picture but after the picture is kind of white and it has lines across the picture
