Question about RCA 27R410T 27" TV
RCA 27R410T Television colors are distorted
Sound works, the picture comes on, but the colors are distorted. I tried messing with the settings but either way the colors seem to be permanently distorted.
  • 566 Answers
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Posted on Nov 01, 2009
  • Jacques Marin
    Jacques Marin Nov 03, 2009
    Please send feedback if my answer helped clarify things
SOURCE:
The picture is fuzzy and the color is distorted. the sound works, but the picture is messed up
It sounds as if it may be the convergence if the picture looks out of alignment or 3D appearance.
May 05, 2011 | Sony KP-51WS520 51" Rear Projection...
Picture is distorted and colors are wavy almost looks like the picture is doubled and color doesn't look right
You can try a new lamp, use the convergence feature to align the three lcds inside. If it doesn't work, you need service.
Jul 30, 2010 | RCA P52936 52" Rear Projection Television
Objects are doubled and colors are distorted
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
Picture/color distorted
If the picture appears as 3D thats a simple and inexspensive repair. You can get the repair kit for your RCA Called "The ITC222 and ITC222A convergence option missing repair Kit" from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Dec 25, 2009 | RCA D52W19 52" Rear Projection Television
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Picture distorted
*Screen Looks 3-D
*Colors wont align
Mar 08, 2008 | RCA P46812BL 46" Rear Projection...
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA 27R410T 27" TV Logo
150 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
