Car Audio & Video Logo
Anonymous Posted on Nov 01, 2009
Have a 2006 tuner/cd/aux audio unit has two plug- in terminals one is a two rows of 5 pins the other is two rows of 11 need to know what each pin is susposed to be connected to
xxxxxx xxx
Level 3:
  • OEM Systems Master 5,117 Answers
  • Posted on Nov 01, 2009
xxxxxx xxx
OEM Systems Master
Level 3:
Answers
5117
Questions
5
Helped
1320692
Points
15645
Select  the MAKE + MODEL of your radio on this free website
(see menu on left hand side )
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Testimonial: "now thats what i call the correct answer excellent site. i think santa may have somthing a little extra for your stocking this year.thx u and fixya"
Radio diagram for 2016 nissan versa
Hi there, Try this...
Radio 12V yellow + radio, white 20 pin plug, pin 19 Radio Ground (chassis, base audio); black/white (except base audio) - radio, white 20 pin plug, pin 20 Radio Ignition blue + radio, white 20 pin plug, pin 7 Radio Illumination lt. green (parking light); black (dimmer, without navigation) +,- radio, white 20 pin plug, pins 9, 8 Power Antenna black + radio, gray 3 pin plug, pin 1 Left Front Speaker (+/-) gray - pink +,- radio, white 20 pin plug, pins 2 - 3 Right Front Speaker (+/-) beige - violet +,- radio, white 20 pin plug, pins 11 - 12 Left Rear Speaker (+/-) white - red +,- radio, white 20 pin plug, pins 4 - 5 Right Rear Speaker (+/-) blue - yellow +,- radio, white 20 pin plug, pins 13 - 14 Aux. Audio Input Left (+/-) yellow - green +,- radio, white 32 pin plug, pins 31 - 15 or white 24 pin plug, pins 10 - 11 Aux. Audio Input Right (+/-) blue - green +,- radio, white 32 pin plug, pins 16 - 15 or white 24 pin plug, pins 12 - 11 RSE Video (+/-) green - (shield) (rear view camera video) +,- radio, white 24 pin plug, pins 16 - 15 Satellite Radio 12 Volts (built into radio on premium audio)
Good Luck
Mr.Mike
Which pins on a 13 pin plug for a bose powered acoustimass 25 series II module would i use just for subwoofer
I know this is late but might help someone plus I had to repair the audio input cable going from my acoustimass 25 series II to the Lifestyle 5 receiver. The 13 pin connecter cable terminates to 2 RCA jacks (red/white) one 3.5 mm jack and a female RCA which is the digital sound source. looking at the connector with the 13th pin on the bottom, I reference the pins from 1-13 starting at the top left:
PIN 1 RCA (RED) center conductor
PIN 2 RCA (RED) sleeve
PIN 3 RCA (digital) sleeve
PIN 4 RCA (digital) center conductor
PIN 5 RCA (WHITE) sleeve
PIN 6 not used
*PIN 7 3.5mm RING (?????)
PIN 8 3.5mm SLEEVE
PIN 9 RCA (WHITE) center conducto
PIN 10 not used
PIN 11 not used
PIN 12 3.5mm TIP
PIN 13 not used
* the 3.5 mm stereo jack is used for system control on the back of the lifestyle 5 receiver, the cable that terminates to the 3.5mm is a 3 conductor cable that terminates to PIN 8 & PIN 12 but PIN 7 only has continuity from the pin itself to the white cable (within the 3.5mm cable) but not all the way through to the 3.5mm ring (where i would assume it to terminate). Maybe this is where my problem is, I don't know but I spliced the cable right before the 3.5mm jack and there was continuity between PIN7 and the white cable that corresponds to the 3.5mm jack I just dont know where its terminating too. If anyone can confirm that it is supposed to terminate to the ring of the 3.5mm connector I would appreciate it.
2answers
Auxiliary too quiet when using my iPod!
clean all conects with acohol and cheak for shorts
2answers
Cable?
Your SOL> Its proprietary cable to that system, and I have the same problem. Can't be found. I've seen maybe two on ebuy in that last 2 years, but missed em both
1helpful
2answers
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
1helpful
1991 Buick Park Ave. climate control stopped working. Replaced electronic (dual zone) climate control module, unhooked negative battery cable to reset module and climate control worked for appx. 3 weeks,...
Check to make sure that you have enought freon to engage the compressor, then you will need a flow chart to take you through the rest of the steps necessary to diagnos this problem. The Electrical system manual for Buick is the only one that will have the proper information for you to walk through the steps to dead head it. There is a HVAC programer that is behind the floor heater duck work. It has a numbering system that goes from (2) rows of pins that go 1-16 for terminals.On terminal 5-7 with ignition in run position, you need bat. votage. Terminal 10 & 11 you need 4-5 volts. Neither 10 or 11 should be unplugged just yet since 10 feeds 11 pin. If there isn't any voltage at these pins, check for corrosion on the pins theirself, or for the pin that it may have slipped back out of the connector. Good luck.
Can i get a connector for the ribbon cable for JVC UX-A4 stereo?
If you sacrifice the Cassette player functionality, you should be able to use pin 6 as ground and cut pin 7 and 8 in the ribbon cable to use as an AUX input instead of the cassette player.
At least that's what I'll try.
Need video jack
I interfaced the SAVV LM-S6001 today. Here's what I found;
Looking straight on at the male 8 pin DIN connector here's how I'll describe it. There are 3 pins across the top row. From left to right I'll call them 8, 7, 6. There are 2 pins on the left side of the middle row, 5 leftmost and 4 adjacent to the center. Moving right, there is a gap and then pin 3 on the rightmost side of the middle row. There are two pins on the bottom row, pin 2 on left and pin 1 on right. Draw that on some paper.
8 7 6
o o o
5 o o o 3
o o
2 1
Pin 1 is +12VDC
Pin 2 is center contact of both audio and video RCA jacks
Pin 3 is -12VDC
Pin 4 is outer RCA contact for Video
Pin 5 -n/c
Pin 6 -n/c
Pin 7 -n/c
Pin 8 is outer RCA contact for Audio
Now, I don't know what pin 7 does, but it is wired next to pin 4 suggesting a video application, Svideo is my best guess. I can only test for a composite video connection that I am using.
It's alive!
3helpful
3answers
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
