Sony CFD-E100 Boombox
Problem for Sony CFD-E100 Boombox
Sony CFD-E100 now only powers up on batteries
By prollec on Nov 01, 2009
Bought approx 15 months ago, my CFD-E100 now only powers up on batteries. The 125V 3.15A fuse is OK. I assume a microswitch is no longer working. Can I short it out as I only want to use the boombox on mains? Or is there another solution? [OK buy a new one which is practically what Sony suggest!! :( ] Tks. Peter
Best Solution
posted on Nov 04, 2009
Very Helpful)
Abrsvcs
Rank: Guru  Sony Home Audio  Expert
Rating: 88%, 1883 votes
The AC inlet needs to be replaced, there are bad solder connections on the PC board for the inlet, or the traces are cracked on the board. I have seen all of hte above over the years for these types of units. The power board can be puirchased for $28.11 using part number: A-1124-986-A from tritronicsinc.com.
I don't have the part number for the actual inlet at teh moment, but I'll try to locate that number for you as well. Check for poor solder connections or a cracked trace first and update this with the results.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony CFD-E100 Boombox
Questions and Unsolved Problems for Sony CFD-E100 Boombox
Do you recommend Sony CFD-E100 Boombox?
Answer
Answer
To replace antenna, do I need to open up the whole radio? I tried to unscrew the small screw but it... (More)
Answer
Won't work as a battery power with 6 C batteries
Answer
can this read am mp3 file on a cd?
Answer
hi, I was wondering if you ever found out what was causing it,? Thanks Gary winsettg at... (More)
Answer
there is no internal or facility for external mic is seen on the tape, it is not recording. his it... (More)
Describe your Boomboxes problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Boombox Experts
Top Audio & Video Equipment Repairmen
in , IL
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
