Mitsubishi WS-65807 65 in. Rear Projection Television
Problem for Mitsubishi WS-65807 65 in. Rear Projection Television
Mitsubishi ws-65807 code 2-2 on
By aabalockands on Nov 01, 2009
mitsubishi ws-65807 code 2-2 on my tv. how do i fix it please, Thanks Jim
Solution #1
posted on Nov 01, 2009
Not Rated)
rylee_smith
Rank: Guru  Televisions & Videos  Expert
Rating: 87%, 963 votes
Hi
Error Code 2-2 means that the short protect circuit has gone bad. Please check the Pico fuses on the convergence board, next to convergence IC's. If the fuses are blown, then you'll need to replace them. To check all of these things you'll need a multimeter to check.
Also check resistor R5K02 (1k,1/4 watt), R5K04 and R5K06 (100k 1/2 watt resistors) on this board. The issue occurs due to component connection failure, so you'll need to check these things to be sure where exactly the issue lies.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Try to reset the TV by unplugging it for 8-10 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Popular Solutions for Mitsubishi WS-65807 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65807 65 in.
Do you recommend Mitsubishi WS-65807 65 in. Rear Projection Television?
Answer
Answer
When I turn on my WS-65807 it clicks on then about 4 secs later it turns off. No pic comes up before... (More)
Answer
I have a Mitsubishi WS-65807 and I'm getting 1-2 code on the diagnostic. The TV won't power up.... (More)
Answer
I'm working on a ws-65807 that had a convergence problem, but is now blowing fuse. I originally just... (More)
Answer
We have a Mitsubishi WS-65807 rear projection television that stopped working all of the sudden.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-65807 65 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
