Why does the heating element in my gas furnace keep shutting off before it reaches the desired temp? The fan keeps blowing but the air is cold. I have to turn the thermostat to off, wait a few minutes and then move the thermostat button to HEAT again. It will not consistantly blow warm or hot air. Thank you
The furnace has many safety controls monitoring many parameters. The most like cause of your complaint may be low air flow. The most simple reason would be dirty or too restrictive of an air filter. If the filter is clean that is about as far as you can go without a general knowledge of how that whole system works together.
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging...
(More)
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging is wire up the low voltage for the heat pump. I can't seem to find out where the wires go from the heat pump. It has 4 wires: Brown
I have a similar problem. It gets up to 78 degrees in the house and the ac unit is set to 65. It...
(More)
I have a similar problem. It gets up to 78 degrees in the house and the ac unit is set to 65. It sounds like it is on all day and my electric bill is rediculous. I have replaced the filter, but have read things about cleaning out the outside unit. Does anyone think that this will help? If so, how do you go about doing it? My duplex management wants to charge me money to send someone over here to look at it...
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut...
(More)
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut off. a/c comes on, and get cold, but blows on low. seem like the switch is switched to on, instead of auto.. CVould this be control board? Thanks
I have a ruud ac unit running heat for the second time this winter and now not heating. blowing cool...
(More)
I have a ruud ac unit running heat for the second time this winter and now not heating. blowing cool air
