Kenwood KVT-719DVD 7 in. Car Monitor
Player says "CALL" upon startup
posted by mcferrando on Jan 03, 2008
Everytime I power up the receiver, it plays the radio or dvd sound for a couple of seconds, and then it ends up saying "CALL" in the upper left hand corner and the sound shuts off. The only way to fix it is by pushing the power button real quick, and then it works. It does this every time I power the system, and occasionally just randomly while I am driving. I did the install myself, and this is the only problem that has occurred. Any idea what's going on?
Comment posted on Jan 04, 2008
Ok thank you I will definitely try that out
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
tom tom 5
Rank:Guru Guru
Rating: 89%, 68 votes
It sounds like the telephone mute wire at the back of the set has got trapped and is shorting to ground and it then mutes the radio, remove the set and look for a trapped tel mute wire and wrap insulation tape around it to prevent it happening again
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Player says "CALL" upon startup:
I don't want to Accept this solution
Can you Help with these Car Monitors problems?
Car Monitors
volume was working before and know it's not it's not muted...
Car Monitors
I have a couple of issues. The sound from the 2 headrest...
Car Monitors
my clock is not storing its time in my renault laguna 53...
due u happen to know the pass code for this radio
i cant getta dvd to play on my unit...sound only from dvd...
Loading problems.
Repair Service
Find Car Monitor Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
