GE WDSR2080D Top Load Washer
Problem for GE WDSR2080D Top Load Washer
GE WDSR2080D top load washer is leaking small
By sgerbs on Nov 01, 2009
GE WDSR2080D top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from the steel mounting bracket but the connections to the discharge hose appeared to still be attached properly? I also found a wet children's sock when I removed sheet-metal to get at the back of the machine. Any advice would be great, thanks!
Solution #1
posted on Nov 24, 2009
Not Rated)
daytonbuzman
Rank: Apprentice
Rating: 0%, 0 votes
Put the sock in a dryer, or hang up outside untill dry. It should be fine
Comments:
Nov 24, 2009
- Put the wet children's sock in a dryer, or hang outside until dry. It should be just fine, however you may need to put it through the wash cycle again.
Was this helpful?
Yes
No
Popular Solutions for GE WDSR2080D Top Load Washer
Questions and Unsolved Problems for GE WDSR2080D Top Load Washer
Do you recommend GE WDSR2080D Top Load Washer?
Answer
Answer
I purchased a GE Profile DPSE810 dryer in July and have started to notice a puddle of water on the... (More)
Answer
My GE Top Load Washer is not spinning and emptying the water. It is washing alright.
Answer
cold water in the bathtub wont come on all the way, the hot water works fine. replaced the stem but... (More)
Answer
my front loading washer is leaving grease looking spots on my clothing
Answer
I need to replace my knob and timer dial on my GE washer. How do I do that?
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
