The product manual for your security system can be found online at
http://www.binkleyalarm.com/Manuals/ITI/Simon%20User%27s%20Manual.pdfYou will need adboe reader from
http://adobe.com if you already dont have it to view your manual.
A fact about your system.
Note
The Master Access Code
default is 1-2-3-4 when the
security system is shipped
from the factory. You should
change your code after your
system is installed (see
“Programming Your System”).
Might try this first.
1. Open the panel cover and enter Utility Access code 1.
2. Unplug the transformer and disconnect the battery.
3. Simultaneously press and hold Cancel, Clock Set, and
Minutes +.
4. Restore power to the panel with either the battery or the transformer while pressing
these three buttons. The panel announces “Hello. System XX OK.” Release
the buttons.
5. Connect the remaining power source to the panel.
Utility Access Code #1 default 654321,54321, 4321, or 321
Comments:
Nov 02, 2009
- sorry didnt see that its a new home new system tell just now
How to change an Access Code:
1. Open the cover of the panel.
2. The panel voice prompts you to Use numbered keys to enter ID. Enter your master
access code using the numbered keys. (1,2,3,4) unless it was changed by home builder
3. The panel voice prompts you to Please select from START MENU. Press the Add
button on the START MENU.
4. The panel voice prompts you to Select from MAIN MENU. Press the Access
Code button on the MAIN MENU.
5. The panel voice responds with Master Code, press again for next access code,
DONE to select or press CANCEL to quit. Press the access code button again to
hear the next access code. When you hear the access code you wish to change
press the DONE Button.
6. Enter 3-6 new numbers using the numbered keys. (Access Code length is programmed
by the installer.)
7. Close the panel cover.
How to Delete an Access Code:
Delete button on the START MENU.
5. The panel voice responds with Access Code 1, press again for next access code,
hear the next access code. When you hear the access code you wish to delete,
press the DONE Button. The panel voice responds with Access Code X deleted.
6. Close the panel cover.
Nov 03, 2009
- ok,
Minutes +.
the buttons.
will reset the code then you can use the previous information above, or in the manual link, to change the code to what ever you want.
