DVD Players
Generic problem for all DVD Players
Disc tray locked on JVC XV-N322
shared by 2 users
posted by Ipan grandma on Jan 03, 2008
Out of the blue, the disc tray will not open and display reads LOCK. Trouble shooting instructions say to press simultaneously both the eject and stop buttons to release the lock mechanisim. LOCK is still not released after several attempts. Any suggestions?
Comment posted on Jan 07, 2008
Dear Mark Evans,
You know what worked - I unplugged the player - waited a couple of minutes - plugged it back in, turned the machine on - and wala! Thanks for your time and effort!!!!
Ipan Grandma
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on May 15, 2008
I have gateway model ar 230, the tray will not open. the window does say open and close. nothing happens. is ther a beltriven this unit?
Solution #1
posted on Jan 06, 2008
Thanks for Trying (70)
markevans
Rank:Wiz Wiz
Rating: 80%, 120 votes
there is a small hole in the front of the tray that will accept a straightened paper-clip. gently insert the clip and the tray should release. if the cd/dvd disc is dislodged from being flat in the tray, it may not come out. you might need to open the cover and manipulate the disc to get it back flat in the tray. a good first test is to see if the disc plays. if it does, it is in the tray correctly and should be easily released with the paper clip. the try might work after you release it.
another possible first try would be to gently push inward on the tray after telling it to release. if there is extra tension on the tray it could cause the mechanism to not release. freeing the tension on the tray could be all that you need to get the 'unlock' to release. (kinda like trying to open a door when someone is pushing it very hard against the lock mechanism. it wont be able to move).
good luck
mark
Rating Locked! (?) Ipan grandma has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on disc tray locked on JVC XV-N322:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
Panasonic DMR-E30 DVD Recorder
I need to make my Panasonic DMR-BW500 bluray/dvd recorder...
DVD Players
no response from the aux input on the front panel of the...
DVD Players
portable DVD player g7131 (NZ import) the discs are no...
Cyberhome CH-DVD 300 DVD Player
N o Lead lite,fuse is ok .Need a schematic with voltage...
DVD Players
DVD hack codes for JVC DVd players
Loading problems.
Repair Service
Find DVD Player Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
