Question about Refrigerators
I have Beko frige freezer, model number nf771 freezer is still keeping food frozen but the fridge part wont stay cool.
Hey Guys, I have a Maytag Bottom Freezer / Refrigerator Model #MBB2256GEQ Serial #10155937AL That runs constantly I cleaned the coils then I turned the defrost timer clockwise until the refrigerator and freezer shut down, it was supposed to go into defrost mode I'm not sure if that happened after approximately 20 min, the refrigerator started up again however it does not keep things cold and is not keeping the food in the freezer frozen it's keeping it semi-frozen. I am not sure if it's the thermostat or the defrost timer. I believe I found where the thermostat is but if anyone can tell me where the thermostat is located on this unit. I would greatly appreciate it and if they can tell me where the defrost timer is located I would greatly appreciate that too and how I can change that out I would greatly appreciate that or whatever suggestions they may have that would solve the problem thank you
Posted on May 09, 2011
  • 236 Answers
- If no voltage output at the thermostat for the supply of heater/reversing valve, then replacement of thermostat is needed (but check the thermostat setting).
- If the voltage output at the thermostat for the supply of heater/reversing valve is present, then then check for heater/reversing valve fuse or overheat protection, and check for defective heater/reversing valve
Posted on Jan 03, 2008
  • Felizardo Erilla
    Felizardo Erilla Jan 03, 2008
    SORRY ANSWERED THE WRONG PROBLEM....:)
I have a beko upright freezer but it has a funny smell in it and it dont keep the food frozen why
maybe you should put a box of Arm&Hammer Baking Soda in it, then plug it in.
Aug 21, 2012 | Beko TLDA662
Is it worth getting my fridge freezer fixed?
Check out the start cap/relay on compressor.
Apr 10, 2017 | Refrigerators
My freezer is keeping my food frozen,but the fridge part is warm and not cooling my model no is 596 69272993 it is a bottom freezer. What could be the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Kenmore Refrigerators
Freezer is not keeping food frozen
the problem just might be honey bees they buzz alot and if the infestation is to out of control it may cause the fridge to thaw the quick fix is to find the queen and remove it the others will follow i might add you may need protective gear for such a heroic feat
Apr 03, 2010 | Maytag 22 cu. ft. Bottom Freezer...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Food is only frozen on bottom shelf
dkburing,
You said, the freezer is only keeping the food frozen on the botton of the freezee. It is cold, but only like a refrigerator.
We need more info,
What is tour brand,model number and the year or age of the fridge.
Waiting for your reply
Huuum
Oct 09, 2008 | Freezers
Side by Side Can't find model # Not cooling enough
I cleaned condenser coils with vacum, emptied the defrost tray and vacumed all the dust from the unit, unplugging first of course. Now it is working just fine. Thank you fixya for all your help and postings.
I still can't find the model number anyplace on the unit. This unit is only 2 1/2 year old but no model number to be found on the unit. But
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
