Question about Seagate (ST3160827AS) 160 GB Hard Drive
Harddrive not detecting
Sir
    ihave problem with my harddrive. when i boot my pc it shows only 100GB amoung of 160Gb . What is the problem.
    Novelist:
    Scholar:
  • 136 Answers
Hi there
the space is still there its just has not been partictioned. Goto diskmanager and you will see the other 60 gig that has not been partictioned, use windows to create a logical drive then format it then you will see the other 60 gig.
good luck
smeags
Posted on Jan 03, 2008
I have a asus Eee pc notebook,when i turn it on the message REBOOT AND SELECT PROPER BOOT DEVICE appears how do i do that?
check if there is any fashdrive or memory card plugged in. if it shows that message it might mean your pc cant detect a bootable harddrive. was it working before? was it dropped or bumped maybe the harddrive got loose. at the bootup screen do you see your harddrive? if your pc can still detect your harddrive try installing a fresh copy or your operating system. hope this helps.
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
Mother board came with pc with 160 gb hard disk I have added 500 gb hard disk in addition thepc isworking well and it cannot recogognice the extra hard disk and I have to tighten the jumper connection of...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
Dec 16, 2010 | Asrock P4I45GV R5 Motherboard
My computer t-40 laptop starts to boot but then shows pxe-e61 media cable disconected pxe-mof intel boot agent,I bought this laptop used ,I was told that it was tring to boot from a net instead of...
Hi there, please try this trobuleshooting steps. after you push the power button quickly tap the F12 key until you reached too boot options menu. once you are already at the menu, select you Hard drive usually harddrive represent as model e.g WDC **** it means western digital. once you slected the harddrive your computer should boot now to your Harddrive. if else fails, waht you need now is to check if you cmputer was able to detect you harddrive. restart the computer then this time keep tapping the F1 key to enter the utility setup. once inside the setup check your system information under internal HDD if motherboard can detect your harddrive. if yes, then all you need to do there is to use the recovery cd that came with the system then boot your computer from the cd rom then install you windows. If not, then you have to contct your manufacturer. that could be a defective harddrive. please let me know if you need more help.
thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
Replaced harddrive and dvdroom wont recognize in bios
Goto bios menu. And change the setting on hard drive and cdrom. It could be it still set in the old configuration. Try to set it in auto detect. Then save the setting. Then goto bios once again to check if the settings doesn't change. Restart again and wait if something you didn't expect still happens.
Leave a comment if this solve cd rom detection.
May 12, 2009 | Gateway M-6750 Notebook
Hard disk siz problem
Use Partition Magic to parition and format the hard drive.
Apr 26, 2009 | Seagate 750GB ST3750640AS SATA300 16MB...
Mount problem for external simpletech 100GB harddrive
Typically points to a hard drive failure. These normally happen without much warning. Have you contacted the manufacturer tech support?
Feb 23, 2018 | SimpleTech 100GB SimpleDrive portable USB...
Possible hard drive failure on SLIMNOTE N12PI
I don't think its a hard drive failure thats causing that message, basically PXE means your computer is trying to boot from a network/server. All you have to do is go into your BIOS setup right after your computer boots. Then make sure your BIOS is set to boot from your hard drive and not anything else (floppy, network etc.). And if possible disable any PXE settings.
Dec 30, 2008 | Twinhead SlimNote N12PI Notebook PC
Seagate 160 gb capacity problem
the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Msi pm8m-v series micro-atx mainboard is not detecting 160gb seagate sata harddrive
Had u properly connected the driver to motherboard..?
U can change the sata cable. Check the power connection also.
Jan 19, 2008 | MSI PM8M-V Motherboard
Seagate (ST3160827AS) 160 GB Hard Drive Logo
83 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
