Question about Kenmore 44832 Front Load Washer
Same thing but stil won't spin??
I have the same Kenmore washer bought also in 2004 (appx). It makes the clicking sound. I took it apart as this on-line tech advised and took out an ink pen and other misc. stuff (have 4 children)! It "seemed" to start and did 1 or 2 loads, but will not spin again?? The clicking NEVER went away. I also took the pump out and it appears to be all there (I think?), but no spinning. Any help please would be greatly appreciated. I can buy a new motor for about $100 but don'twant to waste the money if it won't fix it!!
Thank you.
Thnk you! I did notice the drain hose goes quite a ways into the standpipe (and may be close to being airt8ght). Though it has been this way for years, maybe it needs snaked. I WILL try and let you know.
Posted on Jan 04, 2008
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level when you are re-fitting.
Rate me pl.....if helped.
Posted on Jan 03, 2008
6ya staff
SOURCE:
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
My Kenmore washer (22712) won't spin. It washes and drains.
The number one thing wrong when that type top load washer makes noise and does not spin, is a broken coulper between the motor and the gearcase. This tip i wrote will show how to replace the coupler...follow it to take apart the washer to see if the coupler is broken,if it is my tip will also be helpful to replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My Kenmore agitates while trying to spin??
sorry the repair is a new gearcase appx 230.00 plus labor in your area or buy a new washer ,,,,,
Aug 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Kenmore 70 series washer
your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series - clicking during slugish spinning cycle
try your unit on a outlet by it self ,,nothing can be on this line,,sounds like weak ampage,,this machine needs 15 amps line by it self...
Dec 27, 2008 | Kenmore 24032\24036 Top Load Washer
Electrical clicking, motor lurching sound during spin cycle
its not your unit it your electricity,,you have to many thing on 1 breaker..the unit is asking for power ,,a washing machine needs a breaker of 15 amps by its self..put the unit on a oulet by its self..with no other load
Dec 26, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore Series 80: Loud clicking at spin cycle
sounds like spin tube bad will need to remove basket and gearcase to remove it
Sep 30, 2008 | Kenmore 20172 Top Load Washer
KENMORE ELITE HE 3- MODEL 44832200
is the washer full of water and is the sound like a fast clicking
Dec 31, 2007 | Kenmore 44832 Front Load Washer
Kenmore 44832 Front Load Washer Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
