I am using a sony vaio vgn-n110g from two years, without any issues as such. A month ago the laptop started hanging up randomly, without showing any error or any kind of disturbance on the screen..it would just freeze up. I discovered the fan wasn't working, and gave it to a local expert for repair. Diagnosing the problem , he replaced some ICs on the motherboard, and it worked perfectly well for 3 days after that.but again the same problem shows up now...it just hangs up without any marked pattern, but yes, if the hanging occurs when any music is running, continuous buzzing sound occurs, which wont stop till i switch it off.
I'm posting this from the same laptop,which seems to be OK now, but would hang up in a few minutes from now.
To be honest this still sounds like a fan problem. The freeze will happen if the laptop overheats. Maybe you should have it repaired again by a different company.(ask for the fan to be replaced!)
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN...
(More)
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN i STOP THIS WASTE?
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD...
(More)
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD tersebut.
when i run the software for video it says "this update is not intented for use with your...
(More)
when i run the software for video it says "this update is not intented for use with your computer model"
