The LED readout on my steamist power/temp control unit has stopped. Is this an electrical or battery problem? I've checked for tripped switches on my main electrical panel and can't find any. I haven't had any issues before on the Steamist home shower steamer and then one day the control panel just stopped. Is this an easy fix?
There should be a battery like a watch battery in side of it.
If you have access to both ends of the connector cable we would suggest unplugging the connections and inspecting them to ensure they are clean and dry. also it does not appear that there is a battery in that unit. if you don't have access you may also try resetting the unit by interupting the power for about 5 minutes
is there a battery in the control unit? (Steamist TC-135)? It doesn't appear to have any access point.
Yes. I found the fuse. Thanks.
