Soltek SL-865PE-775G Motherboard
865PE-775G and hang in loading windows
shared by 2 users
posted by phn_uk on Jan 03, 2008
Hi everybody.
I have a very common problem on a number of Soltek 865PE-775G.
when i power on system for the first time, it will hang in loading windows but after restarting it there is no problem and the system loads windows fine. could you please give me some suggestion.
Comment posted on Jan 03, 2008
hi everyone.
I have a very common problem with Soltek 865PE-775G.
When i boot the system for the first time, it hangs up Win XP loading but after restarting it system loads windows fine.
Could anyone please give me some suggestions.
thanks,
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by fertxue on Mar 18, 2008
I have the same problem.
Best Solution
posted on Apr 21, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My guess is that it is a 'bad cap' problem; search google for 'bad cap soltek' and there is more information.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 865PE-775G and hang in loading windows:
I don't want to Accept this solution
Solution #2
posted on Jan 06, 2008
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
it's not windows. there are many boards of this model with the same problem. it's some kind of a Bios problem and i'm looking for a suggestion to solve it.
Thank You!
Solution #3
posted on Mar 03, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
hi, I have same problem such this on soltek SL-86spe-L . It's bios or board problem and computer hangs in first or second steps of bios loading . some times it hangs in windows startup or loading windows.Can any body help me
Thank You!
Solution #4
posted on Jan 13, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
i tried it but didn't help
Thank You!
Solution #5
Not Rated (0)
Guest
Rating: 0%, 0 votes
if you want solve problem you should update your bios.
for find your bios go to google and surf in sl-865-pe
in hope i can help to you
Thank You!
Solution #6
Not Rated (0)
c0nTa
Rank:Master Master
Rating: 84%, 35 votes
its most probably a problem with the windows installation itself, u can either reinstall the windows or there's a better solution but its kinda hard: you have to keep clicking the F8 button when u start your pc, a list will appear, so choose "safe mode" and not any other option, after the windows start you will find a screen asking u if u want to contine in safe mode or if u want to restore system to a previous point, if u click "no" u'll start the system restoration program from which u choose the last time ur windows was working properly and click "restore system to this point" and after that the system will start the restoration procedure and after the restart u'll see if it worked or not, if it didn't then installing a new windows is the only option since there isn't any connection between the motherboard or hardware with the operationg system except if the motherboard doesn't support this operating system.
Thank You!
Can you Help with these Motherboards problems?
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
