Check the fuel lines for cracks/breaks. If they are o.k., then:
You
will need to disassemble the carburetor and spray with carb.cleaner.
Make sure the small screen is free of debris. (Should be able to see
daylight through it.)
I have a Ryobi petrol line trimmer with curved shaft. Installed reeleasy head what a fiasco! Spool...
(More)
I have a Ryobi petrol line trimmer with curved shaft. Installed reeleasy head what a fiasco! Spool is correct way, line is wound in by turning orange knob counter clockwise. When trimmer is started the springiness in the drive shaft allows the head to oscillate a few times & the inertia of the spool winds the line IN. Once this happens the only way to recover the situation is to remove the head, & line, & reinstal both. After about 10 times it may start smoothly & be O.K. & bump feed O.K The idea is fantastic if only I could get it to run without sucking the line in.
my riobi gas trimer mdel Ry30240 star plus ss30 s/n ATJ2071450 i got no spark need to change coil...
(More)
my riobi gas trimer mdel Ry30240 star plus ss30 s/n ATJ2071450 i got no spark need to change coil can you please tell me how to take apart
