Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat
Problem for Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural...
Code c876
By pinkyg on Nov 01, 2009
code c876
Best Solution
posted on Nov 11, 2009
Very Helpful)
JZKlipper
Rank: Guru  Tools - Hydraulic & Plumbing  Expert
Rating: 96%, 90 votes
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support.
If this helps, please indicate so.
Mike//jzklipper
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Rheem RTG-74PVN-2 Natural Gas
Questions and Unsolved Problems for Rheem RTG-74PVN-2 Natural Gas
Do you recommend Rheem RTG-74PVN-2 Natural Gas Pronto Whole House, Natural Gas, Tankless Wat?
Answer
Answer
problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative... (More)
Answer
Our Rinnai tankless water heater doesn't put out hot water like it used to. Our temperature is set... (More)
Answer
vapor sensor reset or new sensor
Answer
Code C2 and 11 comes on when hot water is turned on...have to turn off and on multiple time before... (More)
Answer
I keep getting an error of C2 11 on my Remote Thermostat for the water heater. All of my gas valves... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Rheem RTG-74PVN-2 Natural Gas...:
Top Water Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Water Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
