Heaters
Problem for Heaters
Generic problem for all Heaters
Gas heat radiators in the home
By LUCKYMOM on Jan 03, 2008
For the past three years, ever since my friend helped me bleed my radiators, wrongly I suspect, heat only comes out of the top 1/4 of the radiator in three of the radiators in my home. They are gas heat. I've tried bleeding them again to no avail. It's VERY frustrating(and cold!!). Can anyone please help me?
Thanks so much.
Comments:
Jan 23, 2008
- Bryan, I really appreciate you sending an answer. Since the man(?)of the house refuses to try this, I can't tell you if it works. I would not even attempt to do this myself as I know nothing about this stuff and I would NEVER attempt to work on something of a gas nature. The ? is because a real man would do this for the lady of the house and her children. Sorry. Thanks again.
Solution #1
posted on Jan 05, 2008
Not Rated)
soleman13au
Rank: Wiz
Rating: 91%, 62 votes
Not sure that I can help but will give it a go for you. I have never heard of bleeding Gas Heaters and usually they don't need that. Work on one heater at a time. If you can blow compressed air through the lines this may clear the flow. Best way is if you can get to the gas lines by removing a cover and then remove the gas line as close to the gas source. Gas heaters tend to carbon up and the air pressure tends to clear them. If you can't get to the gas lines you can try blowing the air back through the main jet at the front of the heater. Sounds to me like the jets are partially clogged and just need to be cleared. If you manage to remove the main pipe make sure you tighten it back up to avoid any gas leaks. Before trying to light it check for gas leaks as well. Hope this helps
Regards
Bryan
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
goodman furnases reliability
Answer
best heater for a 5,000 square foot monolithic dome
Answer
rmc kfa120 low pump pressure (2.5psi)
Answer
I have a RBEH-17J14SFAA The blower rattles when unit is running. Motor seams fine but the wheel... (More)
Answer
will load up with diesel and not light I can turn off heater and on sometimes it will light and... (More)
Describe your Heaters problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in Surprise, AZ
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
